Results 1 to 5 of 5
Thread: aftermarket tacho: unknown brand: what are the wiring connections?
    Default aftermarket tacho: unknown brand: what are the wiring connections?
    I got an aftermarket tacho in a wreck I bought.
    It has no brand name unfortunately, but is switchable between 4, 6, & 8 cylinders and has an adjustable shift light.
    There are 4 wires coming out:
    White, red, green, black.
    From pulling the back off, it appears the black & green wires are across the illumination light, so I'd assume:
    black = earth
    green = illumination
    Now I can only guess that the red is ignition 12V & white is the tacho signal as this is the normal convention.
    If I hook it up this way, what damage can be done? (usually the tacho signal is an negative)
    Nov 2011
    Default Re: aftermarket tacho: unknown brand: what are the wiring connections?
    Red is ign
    Black is ground
    White is light
    Green is rpm in
    Except I've already traced the green wire to the illumination lights by removing the back and using a multimeter.
    Nov 2011
    Never seen white wire as signal on a tacho in 20 years
    But anyway just put 12 volts down the green see what happens
    Not my tacho hahahah
    Fair enough. It's my first one.
    I'm not aiming to keep it it's just I'm doing an engine conversion & the donor car has a full-microprocessor controlled instrument cluster, but the recipient car doesn't. The car this tacho came from is the same as the recipient car, but I've wired in a factory tacho cluster instead (except it's small).
    I think I've found the tacho wire into the cluster on the donor car & just wanted to wire this one up temporarily to check.
  1. Replies: 1
    Last Post: 17-11-2011, 08:35 PM
  2. GA61 tacho wires (wiring in tacho booster)
    By Brawler in forum Tech and Conversions
    Last Post: 17-08-2010, 08:19 PM
