Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Legality of exposed cam gears - NSW
    KE20XX Grease Monkey charade_16v's Avatar
    Jul 2007
    Default Re: Legality of exposed cam gears - NSW
    Might just run it open, and keep the covers handy for if I get defected or decide to put it back on...
    Quote Originally Posted by pandaah View Post
    anyone noted that a 5sfe alternator has an external fan with no cover FROM factory?... and they munch your finger hard, let me tell ya!
    Yep, and older commodores are the same - eg circa VN.
    i havent run the front cover for years, and havent had a problem with the po-po even after they sus around under the bonnet. also havent had debris cause a break.
    to get it off a 7m you have to pull the thermostat housing off and drain/refill/burp the coolant. leaving it off makes doing lots of work on the car heaps easier (esp if you play with cam timing often)
    i do like the look, but its more about ease of working on it. my race motor wont run the back one (or lower one!) either cos it will look cleaner and i dont have the room but will still need some sort of TDC mark.
    Never late in an x8
    Supercharged motor has exposed belts even with the engine cover on. The others posted are NA V6s
    If in doubt power out
    Jan 2008
    queensland
    so it does
    my mistake.
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    May 2006
    I think you'e not imagining leaning over an engine naked whilst adjusting a dizzy at the back of a motor, my thumb isn't what I'd be worried about in the belts
    Jan 2008
    queensland
    Quote Originally Posted by beerhead View Post
    i did not want to be so crass as to write penis
    neil
    2009 aurion
  8. #38
    Jul 2007
    Open Pulleys it is!! haha
    you b*tches better rep me for having a pimped out engine bay...
    haha
    Thanks for the discussion ppl.
    Mark
  1. Plumback BOV legality - to airbox or inlet pipe?
    Last Post: 23-09-2008, 10:12 AM
  2. Legality of cutting front to mount intercooler..
    By d-shiznit in forum Tech and Conversions
    Last Post: 21-12-2005, 10:15 PM
