Results 16 to 30 of 38
Thread: Legality of exposed cam gears - NSW
    Default Re: Legality of exposed cam gears - NSW
    NSW = yearly inspections, and RTA roadside checks + narky cops... and probably engineering cert (or are we ignoring that too )
    thats said, the only timing belt failure i've had was due to failure of a pin within the covered area, getting munched between belt and pulley
    KE20XX Grease Monkey charade_16v's Avatar
    Jul 2007
    Quote Originally Posted by oldcorollas View Post
    idiot
    yeah, you tell the cops reading this to... hmmm
    I was just kidding bout the cops, I got all respect for NSW finest.
    Car will definitely be engineered, and pink-slip won't be a problem...
    It's the "RTA roadside checks + narky cops" that I was concerned with, wanted to know if it was illegal by the letter...
    Jan 2008
    queensland
    Quote Originally Posted by charade_16v View Post
    yes!!!
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    fair enough
    the illegal part is mainly so that if someone absentmindedly, say, if they are talking to someone, puts their hand down on the spinning bits while engine is running (not necessarily you... could be someone you are showing the motor to ) and their hand gets munched.
    and.. not all mechanics (even if they will never touch your car) are the brightest candles... "fool proof" comes to mind
    the clear covers look good, and yu could get a clear backing plate made up out of polycarbonate if you wanted to clear that too.
    highly underrated Backyard Mechanic
    Feb 2010
    lol! makes me think of randy from that show my name is earl and how he randomly touches stuff.
    if your that concerned leave it off if you want to but keep the top cover in the boot or something so if you do get defected they might let you off if you refit the part there and then
    RT104 with 4AGTE
    Some assembly required
    Quote Originally Posted by CrUZida View Post
    Simply because thats how the manufacturer made it, and how the regulatory bodies accepted it at the time...
    This makes sense.
    fair enough
    This seems illogical, and if it were the case then all belts would be covered.
    Alternators often have those spinning fan type pulleys on them, and they would be just as dangerous as the exposed belt.
    Melbourne, Victoria
    Look at the exposed belts on this commonwhore......i'd say this would be more of a worry
    - Jackie Stewart
    May 2010
    TAS
    I know two mechanics that have put their hand through a serpentine belt on a commonwhore!
    Cam belts and such are covered I guess as engineers see them as critical for the cars running, and once in place are not even touched until 80-100 thousand kay, such long intervals means they want to keep that area as debris free as possible.
    Where as serpentine belts etc are supposed to be checked for condition and tension at each service interval.
    I think guarding them from peoples hands is actually second place to just keeping general debris out.
    But as said, if it had a cover from factory then I guess for legalities it needs to have one.
    But then again would most cops or RTA type's even be able to tell.......
    Quote Originally Posted by LeeRoy View Post
    although ti seems illogically, that was the reasoning that has been explained to me by a few RTA and enginer kiddies...
    re belts.. here are a couple of commo engine bays..
    there IS a cover for the alternator belt..
    and here, nothing visible
    and again, VS
    the main issue is that the exposed rotating parts are at the TOP of th engine... and if you put your hand don, you WILL contact them.
    a belt further down (water pump, normal alternator position for inline motor) is much less likely to have contact unless you really try
    Jul 2007
    ok, so:
    - It's illegal & dangerous
    - If I choose, I can run the risk, and risk getting defected or hand munched off or crap in belt OR all three...
    hmmm decisions...HAHAHA
    just lock the bonnet closed
    Aug 2009
    anyone noted that a 5sfe alternator has an external fan with no cover FROM factory?... and they munch your finger hard, let me tell ya!
    May 2006
    I heard the reason why they have them is because of a swede nudist mechanic that leant over engine bay to check the timing, don't think too much about it
    Jan 2008
    queensland
    And caught his thumb?
    neil
    2009 aurion
    Jan 2008
    queensland
    Quote Originally Posted by Silly Rabbit View Post
    and the top cover has been removed which covers the belts!
    neil
    2009 aurion
  1. Plumback BOV legality - to airbox or inlet pipe?
    Last Post: 23-09-2008, 10:12 AM
  2. Legality of cutting front to mount intercooler..
    By d-shiznit in forum Tech and Conversions
    Last Post: 21-12-2005, 10:15 PM
