Results 1 to 5 of 5
Thread: How to remove TA22 sill trim?
    Default How to remove TA22 sill trim?
    I need to remove the sill trim on my TA22 to take off the guard and not sure how to do it without breaking the plastic clips. My other car has this trim screwed on but I assume that it has been taken off previously and screws used instead of the clips.
    Any tips?
    Reference pic shamelessly stolen from this site somewhere
    Toymods Club Member Grease Monkey Jeri's Avatar
    Default Re: How to remove TA22 sill trim?
    From memory, they break if force out... So watch out...
    MY TA22 (Now in PRIMER)
    MY KE20 (New pics)
    1975 TA22 Toyota Celica. Working Process
    1974 KE20 Toyota Corolla. In mint original condition
    Nov 2009
    ^^^^ very true, the plastic things that hold it on are irreplaceable, look at each end of the metal trim and see if you can slide it off, or be extremely careful and force it off, but dont wreck the pins, if you do happen to break them, extremely strong double sided tape is your friend
    Melbourne, Victoria
    Nice to see you picked my old car....yeah she was a minter that one......sill trims all straight and in perfect nick ...oh and the panel shop that worked on my other '22 just put self tappers through my sill trims to hold them on......butchers!!!!!
    - Jackie Stewart
    I was able to purchase replacement clips from Toyota a few years ago. Problem is they are old stock, and when I needed to remove the trim piece again 12 months later, the new festers broke.
    To remove the trim, slide a plastic bondo applicator between the trim and the sill, give the applicator a twist, and the clip will either pop or break.
    To re attach, use half a dozen dabs of Sikaflex Urethane on the trim bits, then tape the trims to the car. Clean up any squeeze out with some kero on a cloth. Wait the appropriate drying time and remove the masking tape.
    cheers Chuck.
    MS51Crown Coupe,
  1. trying to remove RA28 windscreen - chrome trim frustration!
    By shewiththe18RG in forum Tech and Conversions
    Last Post: 04-10-2009, 09:19 AM
