Page 13 of 22 FirstFirst ... 31112131415 ... LastLast
Results 181 to 195 of 319
Thread: Wakefield Park Track Day - Friday August 12th!!
  1. #181
    Default Re: Wakefield Park Track Day - Friday August 12th!!
    Quote Originally Posted by whatthe? View Post
    True I guess. Shits me though, this is what I bought the GT4 for. Anyway, the ebay seller is in Auburn and is apparently a CV joint shop, so I havent given up yet
    good to know Matt. I was going to get my shafts from teh same place. I may just call them and have a chat instead of taking a whim purchase.
  2. #182
    The thing is I bought the right ones, they just cocked up the delivery (and have admitted as much)
    Anyway..... Now no-one need be brained with a camry driveshaft
  3. #183
    Car is on trailer, so pretty well ready to go...is it Fri yet?
    anyone want to do a break fluid change and gap some sparks for me?
  5. #185
    Break fluid sounds like vito's area of expertise
  6. #186
    Quote Originally Posted by Draven View Post
    Shouldnt you save these until 7pm Thursday evening?
  7. #187
    well yes, following my usual form.
    Although last track day I was the first one waiting at brooks rd...
    although really I need t obe arriving at wakefield around 1 or 2am, so 7pm is WAY too early to be starting something as simple as a fluid and sparks change
  8. #188
    Speaking of usual form, i'm not sure i'm going to have functioning rear wheel bearings - turns out Toyota and The Internet were right after all and even somebody's "bearing guy" can't magically rebuild a replace-as-an-assembly hub.
    Given i can't find any AE111 rear hubs in Sydney (let me know if you have a line on some!) current plan is find my old AE92/3 hubs and hope that they're as similar as they looked to the AE111 so we can pull them apart and rebuild a combination from old inners with current outers... sounds like a long shot, and i haven't actually found the old ones yet. They're definately not here - that leaves searching the parents place (but not holding my breath) on the way out to linden's tomorrow night after work, which is Wednesday right? And the car will still be up on stands with not much installed in the rear.
    Meh, worst case is i'm spending thursday after work re-installing everything and i go with hubs in the same state i started the week with. But you can easily feel and hear free play with the hub in your hands. Right side is fine though.
    Hmmm; this may prompt action soon after returning this time around.
    Oh, in other news, Ryan rang the Pelican yesterday to confirm numbers for our booking and got told they're renovating the bunkhouse, so we're in 2 cabins.
    Steve, i got you in but you're making conditions tight at the Pelican! At least we have a couple of couples coming so with 12 there isn't a man-man situation in one (or both) of the double beds...
    Toymods Club Member
  9. #189
    Cheers. If need be, I can throw a mattress in & sleep on the floor. Wouldn't be the first time.
    As for the hubs, I've got from my EPC the part number for the RHS is 42409-19015. Does this match your knowledge?
    If so, its the same part number as the AE100 & AE101 Corolla. Might be a bit easier to find, even worst case getting some from a wrecker?
  10. #190
    Que? I get part# 42450‑12040 for RHS - you sure you're looking at AE111?
    First port of call was wrecker gear - there's a chance AE101 might work but i don't remember specs; i know AE92/3 to AE111 has a different diameter for disc centre ring by 1mm but look similar otherwise.
    Oh and probably a good idea to throw a mattress in just in case if you have room.
    Toymods Club Member
  11. #191
    That part number is showing up as AE111. I don't have the chassis number, so maybe it's getting confoosed.
    But it's also showing up as the same as AE101.
    Sounds like ST18# to ST20# Celicas. Same except for centre bore on the rotor.
    BTW, I'll be at the Brooks Rd meeting point.
  12. #192
    Toyota changes part numbers like Rona changes undies (ie; once a year) so I wouldnt take EPC numbers as gospel
  13. #193
    So anyone got a hub they want to donate to science?
    Toymods Club Member
  14. #194
    What're the guys doing in the thread where they're trying to do a 5 stud conversion. Looks like someone in there has got a few hubs around.
    And whilst Toyota might change the part number, inevitably it's discovered that the parts are pretty much interchangeable...
  15. #195
    Jul 2007
    Quote Originally Posted by RONA View Post
    I still have ABS unless I find the fuse and pull it, not sure what else it effects though.
    Why would you want to remove ABS? I mean it's great to learn how to threshold brake, but in reality unless you have a really early abs car with super agricultural spec ABS it will be faster and more consistent than you will ever be....
    Also i did a 1:14 with 80kw less than you + a passenger's weight, no rear brake pads and canvas showing on my semislicks. So if you dont get at least a 1:13 i will laugh at you for ever
    No pressure
  1. Wakefield Park Track Day - Friday November 12th!!
    Last Post: 18-01-2011, 09:35 PM
  2. Wakefield Park Track Day - Friday August 13th!!
    Last Post: 13-10-2010, 06:59 PM
  3. Wakefield Park Track Day - Friday February 12th!!
    Last Post: 11-04-2010, 01:00 PM
  4. Wakefield Park Track Day - Friday June 19th!!
    Last Post: 14-10-2009, 12:06 PM
  5. Wakefield Track Day - Friday 31st of August
    Last Post: 03-09-2007, 04:57 PM
