Page 12 of 22 FirstFirst ... 21011121314 ... LastLast
Results 166 to 180 of 319
Thread: Wakefield Park Track Day - Friday August 12th!!
  1. #166
    Default Re: Wakefield Park Track Day - Friday August 12th!!
    I said a capable driver.
    If in doubt power out
  2. #167
    Quote Originally Posted by Draven View Post
    What issues did the track days cause in the Audi? iirc it performed very well while it was actually at the track
    Wheel bearings failed, brake rotors warped, diff started whining and 3rd gear synchro died (obviously not all at once though)
  3. #168
    oh, crap... that's really not good in a car that new (& expensive), that in theory is designed for a bit of punishment.
  4. #169
    Yes, well, in breaking news I may have to bring the IS-F. The new driveshafts I got (from ebay, so serves me right in a way) don't fit . The splines are about 4mm bigger in diameter than the factory units (32mm vs 28mm). WTF man.
    I know the hubs are right, theyre genuine toyota and fit the old driveshafts fine. Grrr
  5. #170
    Sucks but will be good to see the IS-F getting driven in anger.
  6. #171
    True I guess. Shits me though, this is what I bought the GT4 for. Anyway, the ebay seller is in Auburn and is apparently a CV joint shop, so I havent given up yet
  7. #172
    Jul 2007
    go crack one of the shafts over their heads and ask for a replacement on the spot
  8. #173
    Yeah, theyve admitted theyre wrong (these are 32mm dia and 32 splines, the correct ones are 26.5mm dia and 26 splines) , just waiting to see if they have the right ones in stock now. Pain in the arse, I fitted both sides and didnt realise until I tried to put the hub assembly on
  9. #174
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    they have given you camry ones... it has h append to me on both sides now.... they dont notice the difference
  10. #175
    But some camry ones fit....I have camry shafts off a v6 camry on my GT4, all that needed doing was removing the old gearbox spline of the celica driveshafts and put them on the camry driveshafts.
    Rona: I'd question the better suspension than me, and i also have decent tyres, but the rest is right, so 1:13s is your goal (or something like that)
    Aren't you worried about flat spotting the tyres under brakes though?
    27.90s @ Esses Hillclimb
  11. #176
    My suspension is rubbish and my tyres are nexen rubbish. I was running 1.16s last time but I'm turning up the boost this time so hopefully I can give Nath a challenge (all driveshaft issues getting solved thiat is)
  12. #177
    Quote Originally Posted by Roundy View Post
    Lol I have Aragosta Coilovers with inverted dampers that are worth $4.5k fair to say they should be better then the stuff in your car. You do have swaybars though? My suspension with a proper alignment should be awesome, atm because it is a bit of trial and error it may not be ideal but it is far from shit.
    I still have ABS unless I find the fuse and pull it, not sure what else it effects though.
  13. #178
    just flop your dicks out and be done with it
  14. #179
    Do you think it would solve it??
    I'm keen to see how your wagon does Rona, should be a fairly stout machine.
    I am particularly keen to see the handling balance of it on the track, whether it will demonstrate the totally woeful understeer that seems to plague the ST185s
  15. #180
    Woohoo! The CV joint place says they have the right ones in stock, gonna go swap these camry jobs for a couple tomorrow.
    Back in business
  1. Wakefield Park Track Day - Friday November 12th!!
    Last Post: 18-01-2011, 08:35 PM
  2. Wakefield Park Track Day - Friday August 13th!!
    Last Post: 13-10-2010, 05:59 PM
  3. Wakefield Park Track Day - Friday February 12th!!
    Last Post: 11-04-2010, 12:00 PM
  4. Wakefield Park Track Day - Friday June 19th!!
    Last Post: 14-10-2009, 11:06 AM
  5. Wakefield Track Day - Friday 31st of August
    Last Post: 03-09-2007, 03:57 PM
