Yeah, once things like serious head work and cams are involved, the usual assumptions made for engine VE are well and truely out the window. I think the Garrett calcs are pretty good in most instances, but in your case (and I imagine others as highly modified) you just need to plug in different VE numbers until the boost and HP add up. At the end of the day, it is nearly universal that 10 engine horsepower needs 1lb/min of air so you can always just work backwards from there.
I've just quickly tried a few different numbers, 1600HP at your 6500RPM limit looks like about 30PSI worth of boost unless you can get the engine breathing even better again. Starting to get pretty serious! (not exactly like you were just fucking around before hand though)
