Results 1 to 9 of 9
Thread: 1JZ/a340e aftermarket ecu??
    Nov 2010
    Default 1JZ/a340e aftermarket ecu??
    Hey all, looking for the best/easiest most reliable aftermarket ecu for a 1jz running auto gearbox (a340e) i looked into the Apexi Power FC only to find out auto is a no go without doing a manual conversion and that outta the price range for a R154...
    I dont know much about ecus so looking for the easiest to use or one that is readily tuneable in perth.
    Oh and the car its in is a RA28
    Default Re: 1JZ/a340e aftermarket ecu??
    There is one Power FC that is suitable for a 1JZ/Auto, but that is only the JZX100 (maybe JZZ30) so that limit to the VVTi models only.
    Really, there are only 2 options and that is to piggyback with the standard computer or go stand-alone and run the auto with something like a Supra Stick.
    easiest way is to go manual shift
    http://www.toymods.org.au/forums/sho...0-for-under-10
    Nov 2010
    Quote Originally Posted by sleepercorty View Post
    so power fc + this = win?
    Mar 2009
    The AEM EMS V2 will run the auto if you dont want to pay for a ECU + Auto ECU. Driftmotion have a plug n play kit as well for JZA70's or JZA70 plugs.
    Nov 2010
    jza70 much different from jzz30's?
    will look into the AEM one, they reliable?
    Mar 2009
    Quote Originally Posted by gmonkey View Post
    They're different enough to require you to hack up the harness, but the ECU should still work no probs. Its just a generic standalone pre-loaded with 1JZ maps, get the right software on it it'll run anything.
    They're supposed to be good but I don't know anyone local with one. Will be looking in to one myself at some stage.
    Nov 2010
    do i require main interior loom to do this tiptronic shifter thingo? cause i didnt salvage that from the soarer
    Jul 2009
    Is it a cable line pressure box? You could probably pull a 7M trans computer out of a few people's conversion scrap bins. It's a fairly simple wire up if you have all the right plugs/harnesses.
    Even if you don't have the wiring looms, but you have the right box and can be bothered wiring from scratch you could do this. There aren't too may inputs into the trans computer.
    Otherwise maybe look into a manual valve body?
  1. A340E with 1G-GTE
    By Gem in forum Tech and Conversions
    Last Post: 09-01-2010, 12:13 AM
  2. 1g-gte A340e with 1jz?
    By Z2TT in forum Tech and Conversions
    Last Post: 17-03-2009, 05:31 PM
  3. JZX81 A340E vs MX83 A340E
    By Hibba in forum Tech and Conversions
    Last Post: 26-01-2007, 01:12 AM
