You will need a clutch, flywheel/bolts and spigot bearing for the UZ obviously
The other parts depend on which way you want to go
You can use the auto bellhousing and get an adaptor plate to mate it to the R154 or you can get an off-the-shelf UZ-R154 bellhousing from a couple of places.
Depending on the above you can use the 1JZ clutch fork/bearing, or you can use (or will need) a hydraulic release bearing
In any case, you can use the 1JZ prop, gearbox mount, master cyl, slave cyl (if applicable), pedal(s) (you can mod the auto brake pedal, or use the manual one if you have it), gearstick surround...pretty much anything that came off the factory manual car
I bought a JZZ30 manual halfcut to do my conversion, as you can see it works out by far the best way to do it as most stuff you need just bolts straight in and after you sell off the 1JZ and other bits you dont need it works out relatively cheap too
