Results 16 to 19 of 19
Thread: Lowering CR on factory computer
    Default Re: Lowering CR on factory computer
    I have the oil pump sorted as I have a new 5sfe oil pump with the provision for the sensor and I have a used late 3sfe oil pump with the position for the CAS. Also have a spare caldina crank timing pulley (with half stripped thread in one of the puller holes courtesy of yours truely) and a new 5sfe crank timing pulley with trigger teeth. The issue with using the 5sfe timing pulley is that it is offset (trigger at approximately 4 oclock) compared to the caldina one (trigger at 6oclock) so the caldina ecu would have the wrong crank position if the 5sfe stuff was used. Thinking about machining a relief into the oil pump housing to take the sensor in the caldina position. I'll need to weld in a new piece of aluminum to make it work as there is not enough meat in the current 3sfe/5sfe housing to make it work but that can be done relatively easily enough.
    I looked at your build thread for the cam reset trigger and as I'm fitting the gen1 3sge cam covers for asthetic reasons I don't want to cut into the cover to fit a sensor. I'm already committed to this plan I guess as I have already machined the head in the spark plug area to take a sealing plate.
    BTW I bought a new caldina timing pulley for $80.
    Canada
    The 5S-FE also has a different timing belt tooth profile than the 3S-GTE/GE.
    May 2006
    $80 for a new pulley - would have got one for that price, Toyota wanted $200! Where can I track one down mate? You sounds dedicated to making it work, but dam it does sound like a lot of work...
    I bought the pulley from Amayama. I bought it a few months ago and I've looked up how much I paid and it was $74.25 not including postage. I bought a few other items so I'm estimating that the postage cost for the pulley alone would be $10-15.
    There is a little bit of work to do this project as not everything will be a buy it from ebay and bolt it on proposition. It's more of a idea that I wanted to see if I could do it as its always good to have a challenge and plus I would imagine that no one else would have the same setup so its unique.
    When I get round to it I'll post up some pics of the differences between the 5sfe and 3sgte pulleys and pumps for reference.
  1. te71 lowering
    By blonka in forum Tech and Conversions
    Last Post: 17-03-2011, 12:46 AM
  2. Lowering an MX83
    By orestes in forum Tech and Conversions
    Last Post: 08-12-2007, 10:47 PM
  3. AE80 lowering?
    By funki_munki in forum Tech and Conversions
    Last Post: 26-04-2006, 10:05 PM
