It's more important to make sure the fan sits in the end of the shroud (ie closer to the engine) so it can pull through the air from the radiator. While the blades do flex, they don't flex 15mm.
Trin has the opposite problem. While her thermo fan is properly in the shroud, there is 2mm gap (if that) between the thermo fan motor and the engine. I guess I'm going to do some fiddling about when I upgrade from a double to triple core radiator in the next few months. Lucky I am using a thin arse thermo fan.
seeyuzz
river
