Results 1 to 15 of 23
Thread: 4AGTE-W58 Fly Wheel & Clutch
    Jan 2008
    Default 4AGTE-W58 Fly Wheel & Clutch
    what flywheel and clutch is recomended to go behind a 4agte and a w58? i need some thing that will withstand a fair bit of abuse (26x10" slick and 300+rwkw)
    Default Re: 4AGTE-W58 Fly Wheel & Clutch
    twin or triple plate
    Jul 2007
    pity i just bought one that would suit you perfectly
    Nov 2010
    tasmania
    212 would be the best start with a twin plate????
    Jan 2008
    bastard! wanna sell it?
    otomoto sell a twin-plate
    May 2006
    What bellhousing? Go the AE101 GZE flywheel if you can fit it in there, that way you can go to 225mm, twin plate will cost crap loads. You could get a 1.5 tonne NPC button clutch for around the $600 mark in brissy, if its just a drag car it'll probably outlast the motor.
    Jul 2008
    Auckland
    Twinplate all the way. With a single plate you will never get fast gear changes like you can with a twin. You can only limit the clamp pressure on a single to 3500lbs, after that the flywheel starts to flex.
    I make full twinplate kits to suit your application, have made a few for rwd guys with 4agtes now. Same as what I use on my car - have had the same clutch for over 2 years and 20,000kms on the clock. prob like 100 passes down the strip and many track days. + heaps of around town driving. Pedal feel is also very soft on my setups with a specially designed conical throw out bearing, softer than a button clutch setup with high clamp!.
    Everything costs crap loads these days. But if you want to run that power and esp through 26" slicks reliably then you gota spend the money.
    Now 9AGTE 410kw atw
    Nov 2010
    tasmania
    fark me thats porn.....
    what kinda $$$ we looking at for that clutch setup Bazda?
    KE38 - 2TG
    MS65 - 1UZ
    Jul 2008
    Auckland
    $1640NZD for the complete setup (approx $1250AUD)
    Custom Quartermaster twinplate setup to my specs
    CNC'd billet steel flywheel
    Bolts
    Custom billet steel bearing cradle
    Special Conical release bearing
    Now 9AGTE 410kw atw
    Jan 2008
    thats not bad! what sort o power do you reckon it'll hold? methanol and nitrous might not be to far away from my cars future
    Jul 2008
    Auckland
    They can hold Evo's with 700hp!
    Rated to 600ft lbs of engine torque before they will start to slip a little.
    If your keen flick me a pm and we can sort something out.
    Now 9AGTE 410kw atw
    Tallahassee, FL USofA
    Quote Originally Posted by Bazda View Post
    ???you mean with a curved face instead of a flat surface to meet the diaphragm's fingers?
    Thanks.
    Jul 2008
    Auckland
    Yes its a special conical face bearing like no other.
    The curved face goes right down to the diameter of where the shaft goes through. So the shaft is 40mm, the curved face goes down to 39.8mm.
    All other bearings are usually around 44mm.
    Once I put this bearing in the pedal became super soft, even my wife can drive the car with ease now and she hasnt driven a manual for over 13 years. Just gives you an idea of how easy it is.
    Before this the pedal was pretty damn stiff like a race car.
    Also the bearing in the picture is the older style I used to supply, you can see the conical face doesnt go right down to the shaft.
    Now 9AGTE 410kw atw
  1. Performance Clutch for 4agte AE82
    By dangdang in forum Tech and Conversions
    Last Post: 20-09-2010, 08:54 PM
  2. 4agte clutch setups
    Last Post: 26-06-2008, 11:32 AM
  3. 1g-gte w58 box 500hp clutch fly wheel combi
    By groupasupra in forum Tech and Conversions
    Last Post: 18-10-2007, 04:11 AM
  4. h/d clutch for 4agte
    By bigstickerperformance in forum Tech and Conversions
    Last Post: 14-08-2006, 06:28 AM
