Results 1 to 15 of 16
Thread: Performance Clutch for 4agte AE82
    May 2010
    TAS
    Default Performance Clutch for 4agte AE82
    I've got a crank on the way for my 4agte, so once the bottom end is assembled and I drop
    the head on I can mate it to the gze box and run it in N/A for a thousand kay. So before I get the bottom end back I need to have the clutch ready. Question is which brand, type and size?? Is there any advantage in running the larger diameter flywheels? It seems from the eXtreme catalogue that the really beefy clutches are available in the 200mm flywheel size I assume this is as it is the sprinkler flywheel size.
    Would like this one but cant justify the price lol http://www.tweakit.net/shop/product_...oducts_id=6092
    This is what im thinking I will run, http://www.tweakit.net/shop/product_...oducts_id=4663
    I think with 200kw driveability will come down to judicial use of the right foot more so than an in or out clutch feel.
    Anyone's voices on experience with brands, clutch types etc greatly appreciated, cheers guys
    Sep 2009
    Default Re: Performance Clutch for 4agte AE82
    Im doing just this (running in NA) on my recently rebuilt 4agze block.
    You pretty much have to stay with the factory GZE flywheel if your using the E series gearbox. Only other option will be an aftermarket jobbie. Besides, a balanced gze flywheel/clutch/pressure plate assembly will handle 200kW from what i have seen in the past on other peoples vehicles.
    Excedy make a cushioned 3 puck ceramic sports tuff clutch for the gze flywheel, i dont have the part number at hand but if your interested i can find my box offcut in the shed with the number on it. Im using this exact clutch in my daily and even though its a 3 puck clutch think i can man up and not complain about a heavy pedal or limited to no slip allowed with the clutch.
    I had an eXtreme HD organic cushioned disk style clutch on my first gze'd car, it copped allot of abuse and even though i thought it was gonna be toasted when i pulled it out it had pretty much next to no damage at all, just a small amount of wear.
    thats all i can really help with mate, best of luck.
    try and get your hands on a 225mm 4agze flywheel.... and then you have more clutch options available that wont slip like a poo down a toilet bowl.
    May 2010
    TAS
    Quote Originally Posted by The Witzl View Post
    So E series gearboxes require the larger clutch and pressure plate of the
    225mm fly then? I will pull my finger out and vernier the flywheels I have
    PCD'S to determine what flywheels I actually have and go from there.
    Sep 2009
    Gze fly is easy to identify, it has steps machined into it where the pressure plate bolts to, the rest are all pretty much flat apart from the locater studs
    May 2010
    TAS
    Cheers casey I will have a look in the morning, but from memory I dont remember steps.
    if you want to use a standard GE 200 or 215mm flywheel then you need a custom clutch disc with the larger E/W series spline.
    I'd personally go for the 230mm disc GZE flywheel from the series 2 AE92 GZE or AE101 GZE. Gives you more surface area for the disc to work with. The stock ASIN cover can be modified to develop more clamp force than the exedy covers too.
    yep for sure the gze fly, after screwing around with 2 200mm aftermarket clutches that both slipped quickly, i went to the 230mm fly and a clutch built by jim berry i think. no dramas since.
    4agte Sprinter - 11.7 @118mph WSID
    2.45 @ mount panorama
    1.56 @ eastern creek, 1.10 @ wakefield
    1.24 @ oran park GP
    2.00 @ Phillip Island
    May 2010
    TAS
    I measured the flywheel I have, its a 200mm. Does anyone have a gze flywheel for sale??
    Sep 2009
    Pretty sure TODA make a gze replica,forged/lightened ect..
    $$$ though, i dont know how easy it will be to find a gze flywheel, maybe check the rollaclub forums as well as AE86DC and of course here for one.
    I may have one mate, as I think I will go aftermarket for my build. Send me a PM to remind me to take a look tonight when I get home if you want.
    I agree with JP - go for the 230mm GZE flywheel if you can.
    More diameter = more surface area for the clutch disc to grab onto = less slip = less p00 = more skids
    May 2010
    TAS
    Quote Originally Posted by JP View Post
    Modified asin cover?? Who can do this. More info please JP would be great mate
    I've found a 230mm flywheel also
    I've had them done by NPC and also Jim Berry in Brisbane previously.
    May 2010
    TAS
    Managed to get a 225mm gze wheel from a guy on the forums, will be contacting Jim Berry soon as I have heard fantastic things about his work. Thanks again for the info!
  1. 1jz/r154 clutch problem
    By japlish in forum Tech and Conversions
    Last Post: 12-12-2009, 08:56 AM
  2. Clutch Problems
    By Buttocks in forum Tech and Conversions
    Last Post: 02-09-2006, 10:12 AM
  3. Clutch fork problem
    By Spode in forum Tech and Conversions
    Last Post: 21-08-2006, 11:30 PM
  4. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 01:14 PM
