By tune do you mean balance? They should already be tuned if fitted to the motor and running well before. Balancing them is relitivly easy all you need is a length of clear tube about 5 or 6 mm ruffly 3 m long run it in a loop down a 1 m stick run a little water into it to make a home made manometre then fit both ends to vacumbe fittings on carbs. Then ajust throttle balancing screw between carbs to make water level in tube with each other. just turn up idle set screw on throttle a little to improve idle rpm till balanced.
