Results 16 to 19 of 19
Thread: Help me figure out what this problem is before i burn my soarer!!
    Feb 2011
    Default Re: Help me figure out what this problem is before i burn my soarer!!
    Quote Originally Posted by greg View Post
    i had a similar problem with my wifes vectra , tried everything changed cam and crank sensors as it was logging faults.nothing worked and the problem was intermittant everything checked out and vehicle went fine untill it started to miss and then stop,ten minutes later it would start and run perfectly.it finally cooperated and showed up when we had a meter on it .the internal regulator was faulty and would go haywire and alternate charge rate from 9volts through to16 which caused the ecu to throw up non existing faults untill it gave up and shut down .dealers said they had not had any similar problems but the distributor of the regulators was out of stock and had back orders mostly from holden dealers.
    i wish you luck, these things are bloody annoying.
    cheers greg
    Hi DV
    The above info could very likely be a cause of the system failure the car has. I work in Auto Electrical parts and have heard of many similar faults due to alternator starting to pack it in. I logged into the sales system at work and if the application guide is correct we have both aftermarket ($264) and genuine ($330) units in stock. If you do need an alternator it would help me to find the exact one you require if I have the O/E Toyota or Denso numbers. I also should be able to get a regulator using those numbers if that is all that is needed. You will pay only the wholesale price and recieve a tax invoice for the amount charged.
    You can Either PM me or e-mail me
    Regards
    Mark
    cruisin in a z30 Automotive Encyclopaedia -=DV=-'s Avatar
    thanks both mark and greg.
    Greg your post reminded me of some very strange issues my old 165 was having when the alternater was packing it in. I will test it as soon as I get a chance and post back here.
    Mark thanks for the offer, its really appreciated. Ill let you know if i need one after I give it a test
    JZZ30 Soarer
    wow....only one toyota now, at one point i owned 6....whats happened to me :S
    Dec 2008
    Wellington, NZ
    Are you sure you are not running low resistance injectors on an ECU that
    is designed for high resistance injectors ??
    Cheers... jondee86
    jondee I am running injectors straight out of a supra...well out of a supra then cleaned then flow tested lol. The car travelled 2000km fine on them while i was breaking the new motor in
    JZZ30 Soarer
  1. MZ20 Soarer starting problem
    By whatthe? in forum Tech and Conversions
    Last Post: 05-03-2006, 05:19 PM
