Results 1 to 14 of 14
Thread: 18rg rebuild info
    Oct 2010
    Default 18rg rebuild info
    Hey guys im building a 18rg just wanted to know i have a couple of motors going to build a good one i got 9.7 comp pistons, wondering which head and cams i should use also using a 2t crank which head better 250 ?? 270??
    The 270 head had the fuel injection but i wanna run twin solex and the cams i got are number matching to the heads?? Any info would be great
    "I LIVE MY LIFE 1/4 MILE AT A TIME"
    Oct 2010
    Default Re: 18rg rebuild info
    Any one????
    Start reading here...
    http://www.toymods.org.au/forums/sho...s-of-the-18R-G
    Ask questions once you are done
    Now - RA23-WRX
    Ok Toy.
    There is the 18R-G Tractor engine thread with a stack of info in amongst the waffle.
    There is the T series engine thread started by river.
    {Too slow with the typing, good one Silver}
    View these threads to determine which engine you have. 18R based twin cam 18R-G or a T based twin cam 2T-G? Two very similar looking engines of 2lt and 1.6lt respectfully. R and T motors do not mix.
    If in doubt please post a picture and we can very quickly identify the motor.
    Any rebuild of a motor benifits nowdays, with the quality of the fuel (even ULP), on better compression so start there with the higher comp pistons.
    You are in the right forum now we need only sort the facts from the unlearnt.
    Regards
    Rodger
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    I have an carb 18RG head that I am willing to swap for an efi one if your keen?
    Kind regards,
    Ryan
    Oct 2010
    Hey guys cheers for the info i think my set up we be 9.7 piston bored 1.00 thou, 88250 head, 88230 cams, which manifold though 88250 or the 88230??
    Also running a 2t crank
    I am going to have to ask.
    How is it you believe you have a 2T crank in an 18Rg?
    Your creditability is waning Toy_RA28 in this thread. Please research which motor you have.
    Regards
    Rodger
    I dont think he has any idea what he has.
    Is you distributor in your timing cover(18rg)or in your block(2tg). That's the easiest way to tell by looking at it.
    Oct 2010
    Hey guy's sorry umm checked it last night it has 2t on the main bearing cap definitely 18rg
    Dude. A 2t crank will NOT fit in an 18rg.
    I think someone has sold you a pile of random parts and ripped you off. Sorry but from here that's how it looks.
    Oct 2010
    Thats cool but the cap does say 2t could possibly the 2t caps fit????? The motor was running
    I don't think the lettering means anything. My 3tgte,2tg,18rg,18r. None of them have anything meaningful on the bearing caps apart from arrows.
    Oct 2010
    Oh ok cheers for that which cams do you think i should run?
    As mentioned in Post #3 in this thread, there is already a large 18R-G thread. We also have a thread on turbocharging an 18R-G.
    I know these are long threads, but amongst the waffle they are packed with a goldmine of useful information. Instead of starting yet another 18R-G thread (which kills me, as we all know it's the greatest vehicle engine ever built) I am closing this one so you can use the existing threads for this topic.
    seeyuzz
    river
  1. gen 1 3sge rebuild info
    By mattysshop in forum Tech and Conversions
    Last Post: 25-05-2010, 07:20 AM
  2. T50 Rebuild info
    By bazzery in forum Tech and Conversions
    Last Post: 24-06-2008, 06:40 PM
  3. 2tgue rebuild info
    By poida in forum Tech and Conversions
    Last Post: 12-03-2008, 10:33 PM
  4. 18RG rebuild OR 1G-GTE
    By ansonvd in forum Tech and Conversions
    Last Post: 19-07-2006, 05:07 PM
  5. 18RG rebuild Q's
    By tricky in forum Tech and Conversions
    Last Post: 30-12-2005, 12:58 AM
