Results 31 to 45 of 47
Thread: Bad Bad Engine Noise. Could anyone rectify it? Sound Clip provided
    Default Re: Bad Bad Engine Noise. Could anyone rectify it? Sound Clip provided
    I am skeptical that it is a bearing. noise is no-where near consistent enough. Please start doing thorough testing and let us know what you find.
    Dec 2009
    After further investigation the noise is changing quite a lot when putting the clutch in and out.
    I am betting:
    Loose pressure plate
    Loose Flywheel
    Broken fins on pressure plate
    Maybe Thrust Bearing
    I used loctite on all bolts, new toyota flywheel bolts were purchased as were new pressure plate bolts.
    I did purchase a heavy duty clutch kit too.
    ZZT-231 Toyota Celica SX
    are you still driving this?
    Interesting. When you pull the gearbox off let us know what you find.
    Original Trendsetter Chief Engine Builder Harreh's Avatar
    Jul 2008
    Quote Originally Posted by trd_st184 View Post
    I am betting:
    Loose Flywheel
    Hope it wasnt an Exedy heavy duty >_>
    AW11 Turbo build
    1UZ Soarer Turbo build
    Imitation is the most sincere form of flattery
    Dec 2009
    Nah not at all, this car hasn't been driven since the original video. I just started it again to try rectify the noise some more.
    Quote Originally Posted by Harreh View Post
    I got a custom one made up from a company called disk brake and clutch
    did you pull bits off and follow the list of diagnostic procedures or just start her up and faf around some more?
    EP82 Starlet GT - [URL="http://www.toymods.org.au/forums/forum-members-rides/71090-stus-ep82-starlet-gt.html"[/URL] SOLD
    EP82 Starlet GT V2.0 - http://www.toymods.org.au/forums/sho...98#post1514198 SOLD
    The IS400, GXE10 with 1UZ - http://www.toymods.org.au/forums/thr...8-StuC-s-IS400
  8. #38
    Dec 2009
    Quote Originally Posted by StuC View Post
    Hey mate,
    I was tempted to take off the sump to have a look but on further inspection with the steteskope it was coming from the gearbox side, and the on and off transition with the clutch in was more obvious when i looked for it.
  9. #39
    Jan 2008
    queensland
    Gearbox off dude, and take some pics of the damage, sounds like maybe the throw out bearing has come adrift, they usually have wirey clipy type arrangements to hold them in place, maybe it wasn't quite clipped in properly.
  10. #40
    May 2010
    TAS
    Clutch? Flywheel?
    Discovered what it was yet?
  11. #41
    Dec 2009
    I took it to a mechanic, he started it up and confirmed it a bearing was stuffed.
    Looks like i'll be needing to get it rebuilt. Would you believe i just sold my spare 3sgte motor last week?
  12. #42
    Canada
    No, I wouldn't.
    Why would you sell a spare motor when yours is questionable?
  13. #43
    Dec 2009
    Bit of shocking news.....
    The Mechanic mentioned that 2 of the Flywheel bolts were able to be removed with his fingers.
    I've always feared this:
    I can't see where I could have gone wrong.
    1. I used a good quality Torque Wrench
    2. I used High Strength Loctite on all the bolts
    3. I used the recommended Tightening Sequence Order
    4. I used brand new Toyota Flywheel Bolts
  14. #44
    Dec 2009
    Quote Originally Posted by 3sgte View Post
    No, I wouldn't.
    Good Question, my mate who was keeping it for me for quite some time required the space, and it was only fair to let it go and organise to rebuild mine instead.
  15. #45
    May 2010
    TAS
    Where the mating faces on the fly and crank perfectly clean and lined up straight, doesn't take much.
    So it's just a loose flywheel? Or the bearings, as you stated the mechanic said?
    Or he just got as far as the flywheel to realise it was that and not bearings.
  1. should i spray sound deadner in engine bay
    By bigmat in forum Tech and Conversions
    Last Post: 06-09-2007, 01:47 PM
  2. motor noise ? rattling.. vibrating sound ?
    By Jorrs in forum Tech and Conversions
    Last Post: 05-09-2006, 11:48 AM
  3. Replies: 47
    Last Post: 16-01-2006, 05:08 PM
