Results 16 to 22 of 22
Thread: 3sgte rwd sump
    highly underrated Backyard Mechanic
    Feb 2010
    Default Re: 3sgte rwd sump
    ill check it out next time im out there which atm seems likely.
    couldnt you just use the spacia bellhousing what gearbox do you use for rwd conversions eventally ill be doing one on my corona
    Feb 2010
    sorry guys somebody beat me to it the sump was gone as was the car i was chasing parts off............doubt ill be allowed back there for a while
    May 2006
    Bad luck, only 2 years of the 3S powered spacias 98 and 99 I believe, so fairly hard to come by.
    I pulled the sump off this spacia as was keen to see the difference over the 2s sump. Didn't appear to be majorly different plus there was no windage tray but the sump looked like it had been pulled off at one stage and refitted as the goo wasn't factory so maybe they left it out or fitted a different sump as this spacia was in a acco and the sump could have been damaged. I left the sump and pickup all nicely pulled off in the engine bay so I guess someone else took them. Did take the engine mounts though for my 3sgte and they fit perfectly solving the issue of part of the mounting holes on the intake side of the block being ground away. Will post up some pics in the a new post in the tech section to share the knowledge.
    May 2006
    Dam EPC, they showed the same integrated windage tray as a 3SGE sump! Doesn't mean that toyota didn't use the rest of there spare 2S sumps on the aussie spacia's though! I've pulled apart aussie 3VZFE's that had the notoriously weak 3VZE rods in them!
    Feb 2010
    so to redig this thread howd the 3sfe spacia sump work out? ive spent much mucking about with motors for the rona 22r, 18rg and now a 1ggte but im rethinking the 3sge/gte option it makes more sence given the layout for the fuel lines and exhaust theyd have to be swapped over to use the 1g not to mention all the fabrication work for the sump and turbo manifold....yada yada
    RT104 with 4AGTE
    Some assembly required
    Low rep Grease Monkey
    Apr 2010
    bkk
    good luck man
  1. 3SGTE with custom modded sump...how much oil will I need?
    By Joel-AE86 in forum Tech and Conversions
    Last Post: 22-07-2012, 02:32 AM
  2. RWD 3sgte baffled sump
    By af300e in forum Tech and Conversions
    Last Post: 24-07-2008, 11:07 PM
