Page 37 of 43 FirstFirst ... 273536373839 ... LastLast
Results 541 to 555 of 634
Thread: Megasquirt users thread to discuss all things Squirty
  1. #541
    Jul 2009
    Default Re: Megasquirt users thread to discuss all things Squirty
    Gonna try out some extended tables tomorrow on the MegaSquirt using some table switching based on RPM.
    32x16 Fuel table, 24x12 Ignition table.
  2. #542
    mmm colourful good luck!
  3. #543
    You really need that much resolution?
  4. #544
    Jul 2009
    Most certainly not, but a common thing people bag the MS out for is "having low resolution"....
    If I can make this work and it doesn't cause any issues, I can then till those people to STFU and how they could use this method.
  5. #545
    Hehe, fair enough.
  6. #546
    TinyIOx turned up today
    Didnt think it would be that tiny
  7. #547
    Jul 2009
    In case a couple of you have missed it, the new MS3 Pro launched on the 1st Jan from DIYAutoTune.
    $1199.00 - http://www.diyautotune.com/catalog/m...ess-p-538.html
    The MS3-Pro combines the features of the legacy MegaSquirt-3 with all available 'expansions' built right into a single circuit board in a sealed case. The o-ringed case is splashproof and, if you want continuous immersion resistance (the MS3-Pro displayed at PRI was at the bottom of a fish tank), it's easy to add a bead of silicone for extra protection. Furthermote we've updated the power supply design to use a switching power supply to minimize energy consumption and maximize stability of operation (down to as little as 6v!). We also included the new intelligent knock sensor capability allowing for advanced knock windowing and noise threshold configuration, integrated internal SDCard datalogging with time stamping of all datalogs, USB and RS232 Serial tuning interfaces, individual cylinder tuning for fuel AND ignition timing to allow you to compensate for differentiation in flow characteristics to different cylinders and truly maximize engine output, and more!
    The MS3-Pro is ready to support a wide variety of engines out of the box, with the ability to anything with one to eight cylinders with sequential fuel injection and sequential 'coil on plug' ignition, a V12 with sequential fuel and wasted spark ignition, or a four rotor Wankel with separate leading and trailing ignition outputs. Over 50 different ignition modes are supported, from mainstream applications like the GM LS1, Bosch Motronic, and Chrysler Gen III Hemis to unusual modes like Renix Jeeps and the Suzuki Swift GTI.
    The MS3-Pro's packaging is also a departure from most previous MegaSquirt EFI Systems. Instead of the industrial looking split aluminum case and D-sub connectors, the MS3-Pro uses a sealed high temperature nylon case for light weight and compact size, and heavy duty AMPSEAL connectors. This provides a compact and sealed enclosure protecting the sensitive internals from the elements. The MS3-Pro's design keeps the heat generated to a minimum, allowing it to use a lighter plastic case instead of a metal heat sink.
    Hardware features:
    Freescale MC9S12X 16 bit, 50 MHz asymmetrical dual core processor
    10 saturated injector drivers
    8 logic level ignition outputs
    3 high current (5 amp) general purpose outputs - 2 can be reconfigured as additional injector drivers
    3 medium current (3 amp), high frequency general purpose outputs
    All unused injector and ignition outputs can be used as SPARE outputs. This ECU has a LOT of I/O!
    1 stepper H-bridge driver
    Camshaft and crankshaft differential inputs - supports VR, Hall effect, and optical input
    12 volt tach output
    Fuel pump output
    8 analog inputs (5 dedicated sensor inputs, 3 spare/general purpose)
    4 spare digital on/off inputs
    3 spare digital frequency inputs
    2 knock sensor inputs
    RS232, USB 2.0, and CAN communication
    Onboard 8 gigabyte SD card for internal data logging
    Internal ECU temperature sensor
    Real time clock
    Temperature range: -30 to +80 degrees C (-40 to +85 without battery for real time clock)
    Software features:
    Supports speed density, alpha-N, or MAF based fuel and spark tables
    1 microsecond injector pulse width resolution
    Tables for nonlinear injector behavior at small pulse widths
    Allows blending multiple load types, including specialized mode for independent throttle bodies
    Supports a wide variety of OEM cam and crank position sensors
    Individual cylinder trim tables for fuel and ignition
    Accelerator pump or model based acceleration enrichment
    Closed or open loop idle speed control
    Closed or open loop boost control with gear or speed based tuning options
    On/off or closed loop continuously variable valve timing control - supports up to 4 channels
    On/off or progressive nitrous control
    Traction control
    Rally anti-lag
    Rotary support - can run up to 4 rotor engines with separate leading and trailing spark tables
    Staged injection
    Table switching
    16 x 16 fuel and spark tables - can be reconfigured to function as 30 x 16 or 16 x 30 by switching tables based on RPM or load
    2 or 3 step rev limiter with no-lift shifting
    Wideband AFR target tables
    Flex fuel sensor input
    Allows repurposing injector or ignition outputs as general purpose outputs, or high current outputs as injector drivers for 12 cylinder sequential applications
    Real time barometric correction
    A/C and cooling fan control with idle compensation
    Safety shutdown based on AFR or EGT input
    Sequential shift cut and air shifter control
    6 General purpose on/off or PWM inputs
  8. #548
    it only seems expensive because of where MS has come.. not compared to other popular alternatives
    Bruce and Al must be so proud their little baby has come this far
  9. #549
    Jul 2009
    Bruce and Al might have spawned the platform, but it's really James, Ken, Matt, Jean and Jerry that have really made it what it is today.
    The MS3 Pro is 'expensive' compared to the other MS family members, but it's a pro solution that is designed to be work with any car without having to wire up extra circuits on protoboards and fiddling with adjustment pots.
  10. #550
    so the two oldies didn't have that much input into the polished "solutions"?
    mustardmitt, i'm a bit out of touch
    whoever it was, they've done a cracking job
  11. #551
    Jul 2009
    B&G don't really provide anything to the MSExtra community from what I have seen (I could be horribly wrong...) that doesn't already come from the B&G MS hardware and code sources.
    The MS3 Pro is entirely a DIYAutoTune project (Matt & Jerry), but it's built on the software and features pioneered by the MSExtra community and the leading heads (James and Ken).
  12. #552
    Just about got my megasquirt install on my 7k efi and supercharged 4k, got the squirt powered up for the first time and got a few weird things going on.
    First thing is when you power on the fan relay buzzes then turns the fan on for a split second, then shuts off. I have the fan triggered via the IAC 1 wire.
    Also I have trouble with the ecu showing weird rpm readings, I am just running a locked 5k electronic dizzy, and getting the crank signal from the neg side of the coil.
    Ecu is ms2 3.57smd running ms extra
    Matthew
  13. #553
    Aug 2008
  14. #554
    Quote Originally Posted by Smithius View Post
    Matthew
    i have 4K with 7K efi too but wth 4KE dizzy.
    when triggering from the coil, I had to run a resistor to get it to read without noise (MS1 and MS2)
    i'll see if i can find it.. (had it set up with RCA connectors).
    am now running basically an ignitor setup to get clean rpm signal with the MS2
    re fan, what settings do you have for that output? does it have hysteresis set up etc? is the behaviour you're seeing what you'd expect from the IAC output if it thinks an IAC is connected?
    edit: 15Kohm resistor between coil neg and MS to get clean feed..
    i foudn that value when still running on carb, and connecting MS1to coil to see when rpm signal became smooth.. many years ago LOL
  15. #555
    So just a 15kohm resistor on that signal wire? I'm pretty sure that I have it triggering the relay negatively but haven't changed any hysteresis values yet but did a little research, 6.0 sound ok, what would the setup be, 0 and 0?
  1. Overboost caused by plumb-back BOV wrong way round! Discuss...
    By Stefan in forum Tech and Conversions
    Last Post: 03-09-2008, 03:39 PM
