Results 16 to 24 of 24
Thread: Maf Conversion Issues
    May 2010
    Moscow
    Default Re: Maf Conversion Issues
    Vacuum gauge shows pressure in your intake manifold, within the limits of 0 and 1bar (with 1 bar pressure standing for zero vacuum). Charger makes excessive pressure, so sometimes there will be more than 1 bar and thus you will need a boost gauge.
    However if you run boost gauge with N/A engine it will work right but obviously it won't show any boost (pointer won't go anywhere positive)
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    Look at turbo cars they run the air flow and air temp before the turbo and even before the intercooler so i dont think its going to be an issue, if going with the MAP sensor and you have the supercharger you will defanetely need a boost guage
    May 2010
    Thanks fella's the issue is resolved, I have found the correct gauge Vacume + Boost and is supplied with a MAP sensor (ATM 4376)
    so you will be running a MAP sensor now? good to hear if you are. Let us know how u go!
    May 2010
    After hours of research "YES" there is minimal differences, but there is more opertunities to manipulate MAP sensor imputs to the ecu, i believe.
    There is a dual reostat system that can be put between the MAP sensor and the ecu, what this does is, gives you the the opertunity to manipulate the signal to the ecu therefore increasing tunability via the AFR meter readings.
    Quote Originally Posted by TOTGAS View Post
    thats an old school way of tuning by frigging with map voltage. I assume this is a relatively old ecu?
    May 2010
    NO its new, a basic stand alone unit. With MAP imput so i have found out, I am just learning and feeling my way "cautiously" as i have never delt with ecu, MAP or MAF before :-)
    how much are these units? if you havent already got one you might want to explore some other ecu options to ensure value for money.
    May 2010
    I have already purchased one for, all up $315.00au to my door. It is already in my vehical, i have not wired it in yet and the fella's in the forums sent me a few maps to get me started. So i really can't complain to much. It came with mag adaptor (for free) as it works better on square wave although it does work with sine, and an TP100 igniter. Its simpliciy, cost and recommendations is what sold me.
    http://www.dicktator.co.za/standardecu.html
  1. MA70 --> JZA70 Conversion
  2. ST162 Conversion
    By Pure-SX in forum Tech and Conversions
    Last Post: 30-01-2006, 01:34 PM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
