1st year Apprentice
Dash and air con electrical problem
Hi guys,
I have spent too many hours trying to fix this without consulting help. So here I am.
The car is an auto soarer 6 cyl 1jz.
Dash and air con were working fine. Never had problems. One fine hot day followed by rain, power windows and air con stopped working at the same time. The dash also no longer displayed the number of kilometers driven.
I tracked the power windows problem to a loose connection on the driver's side door. Where you lift the little tab to pull the window up, in this dirvers door, theres a connection (requires door to be taken apart) that connects to the board where you have the tabs to control the windows, side mirrors and central locking. Basically, the connector to this had dropped off.
With the power windows fixed, air con and dash problems remain. I have checked all fuses. One fuse was busted, but changing it has made no difference.
Any suggestions?
Waldo
Reason: Soarer is the car
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
