Results 1 to 2 of 2
Thread: 4AGE erratic idle
    Aug 2010
    Default 4AGE erratic idle
    AE92 Smallport 4AGE. Finally got everything back in the car and connected up to get the engine running. It's a little hesitant to start (probably because I've got no cold start injector) but once it kicks it will idle fairly smoothly for about a minute or so. After that it pulses from 1000-2000rpm every second or two, like constantly blipping the throttle, except I'm not touching anything.
    I'm no longer running the idle control valve, as mine was dodgy. Its currently setup with a solenoid valve which I manually control, so that shouldn't be affecting anything.
    Car was previously power steering, but I converted to a manual rack and plugged off the lines.
    Timing may be a bit off, as my timing light broke.
    I'm a little stumped as to what might be causing this. From what I know I've got 100% control over the airflow into the engine, so without touching anything it should be stable. It definitely seems temperature related, as it works fine while warming up. Any suggestions as to what I should look at next?
    Sep 2009
    Default Re: 4AGE erratic idle
    check timing and then go over all your vac lines checking for leaks.
    Map sensor may have gone to poo?
  1. Lexus V8 idle probs
    By mick08 in forum Tech and Conversions
    Last Post: 27-05-2010, 09:35 AM
  2. 4AGE 16V - Idle Hunting
    By Tom4AGE in forum Tech and Conversions
    Last Post: 11-07-2008, 07:30 AM
  3. High 4AGE Cold Idle
    By toaster in forum Tech and Conversions
    Last Post: 23-10-2005, 04:08 AM
