Results 1 to 6 of 6
Thread: Larger clutch master cyl for MA61?
    Default Larger clutch master cyl for MA61?
    With the new Howe release bearing, the takeup of the clutch might be a bit touch and go, although it seems to work. Howe recommend a 7/8 or 1in master cyl, has anyone tried finding a larger/replacement one? I'm thinking landcruiser, but no idea if it'll work...
    -RM
    Default Re: Larger clutch master cyl for MA61?
    Woops... Sorry misread ;p
    Daily: '06 Liberty 3.0R specB
    Jan 2007
    queensland
    possibly use a 'combination master cylinder' as a clutch master? being a universal unit you can pretty much do what u like with it...
    http://www.wilwood.com/MasterCylinde...inderList.aspx
    we used a 1" remote master and it wasn't even $100 delivered...
    I know of one UZ manual conversion where they had the stock 5/8" Supra/Soarer Master bored out to 3/4, which did the trick. They were also using a Howe...
    Yeah, nathan did the same thing, quite an expensive process though!
    Ok, to wrap this topic up: I've bored out the factory master to 3/4 inch and made a new piston for it...to be honest, it's too big at 3/4, the pedal is a lot heavier, but the takeup is a lot sharper and more consistent now. Further down the track I might make another one and take the size down to 11/16 (or the metric equivalent that I can get seals for )
    -RM
  1. Clutch master pushrod
    By mr1jz in forum Tech and Conversions
    Last Post: 03-12-2010, 02:06 PM
  2. GX81/JZX81 clutch master cyl part number!! halp!!!
    Last Post: 27-05-2010, 11:15 PM
  3. mx83 clutch pedal & master cylinder
    By Dale in forum Tech and Conversions
    Last Post: 29-03-2008, 07:08 PM
  4. Tips with clutch master cyc (pics included)
    By eighty-eight in forum Tech and Conversions
    Last Post: 12-08-2007, 10:15 PM
