A jzx90 master cylinder will bolt up to the mx83. I`m using a 94` camry master cylinder with a camry clutch pedal and it works perfectly with the r154 slave.
ive been looking for like a solid hour on toyodiy, can cannot fucking find the part number for this .
i need to order one from japan but need a part number!!
help me boys!
ps. this is for my old GX81 that my mate owns now with a 2JZ/R154
so would he actually need a master cyl for a R154 or would a GX81 / W58 master cyl work on the r154??
i read ages ago the jzx90 fit on mx83 ?
You mean slave cylinder? if so no they are different between the W58 and R154 as i got both of them.
I have a clutch master cylinder i got no use of as i got a JZA80 one im using.
Unsure if its a X81 or a A70 one but they both look the same.
i have a JZA80 pedal box and clutch master and they fit without no problem in my MX83, i was pretty surprised it fitted fine.
is he using the twins or going single?
-Sleeper 2J + R154 X83
-GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
hes got twins on it now, probably one day will go single.
none the less
Heng if you know for certain the one u have spare fits, then he'd keen to get , got money will pay asap
Hes running twinies he will need to use a JZA80 clutch master cylinder thats if hes using the JZX81 engine mounts and stuff. Unless he made custom mounts and shit then he might get away with the normal a70/x81 master cylinder.
Cause if you gonna use the original a70/x81 clutch master cylinder it will hit on the rear turbo. Thats why i went to a JZA80 item should be same as x90/100's/z30 aswell i think, correct me if im wrong though.
Link here shows it all.
http://picasaweb.google.com/seufert/2JZ_Nearly_Done#
Jza80, clutch cylinder - 31410-24050
My mate bought a JZA80 clutch master - got a new genuine toyota one for $230.
took the studs out of the pedal box, installed the master and all is sweet .
thanks heaps for everyones help !!! car is now ready for engineering .
thanks again.
good to hear, mate.
nowpicsofsaidcarwith2jznoshitinit
