Results 16 to 22 of 22
Thread: F-series Trutracs.... new part number, different bearings, still works?
    Apr 2009
    California
    Default Re: F-series Trutracs.... new part number, different bearings, still works?
    also heard somewhere that taco front diffs had 50mm. think on custom tacos for people using mk2 and mk3 LSDs rears for 4WDs instead of forking out the dough for the TruTrac or TRD units.
    1983 KP61 - High Comp 4AGE, Celica-Supra Rear, etc.
    1971 Volswagen Baja Bug - 1835cc, Megasquirt, Type 2 Trans
    1997 KZN185 - 3RZ W59, Tundra Front Coils, ELocker
    Well according to Rich at DTS the 911A342 and 911A644 are both 50mm bearing units.
    Ill have to ask him about the 911A565
    teq Grease Monkey
    California
    So to sum up, a 911A644 diff with standard Toyota bearings will bolt in, all hunky dory, and seem to be about $400US?
    teq Grease Monkey
    California
    Yep... although according to Eaton it will not work as well in a RWD application as the 911A565.
    This is due to the design difference in the way the gears are cut and how the torsen works in transfering power.
    Andrew
    Is this the same situation which can be fixed by pulling it apart and resetting the gears?
    teq Grease Monkey
    California
    Good question, I don't know the answer tho...
    Andrew
    By The Witzl in forum FAQ
  2. GX81/JZX81 clutch master cyl part number!! halp!!!
    Last Post: 27-05-2010, 10:15 PM
  3. vacum sensor part number
    By bassy in forum Tech and Conversions
    Last Post: 09-07-2006, 09:02 AM
  4. Guide: Removing paint from plastic parts (more input needed)
    Last Post: 13-04-2006, 01:09 PM
  5. 1UZ-FE part number ID and help needed
    By scootaphill in forum Tech and Conversions
    Last Post: 09-01-2006, 03:26 PM
