Results 1 to 15 of 21
Thread: 20v silvertop blows smoke
    Feb 2010
    Default 20v silvertop blows smoke
    Under decent load and above 4000rpm i can seee black smoke pour out the exhaust, lots. Car eats about 1ltr of oil every month roughly. Does this sound like stem seals or oil rings? Either way, up for a rebuild?
    Oct 2009
    Default Re: 20v silvertop blows smoke
    Valve stem seals for sure. The job can be done with the head on, but if you want it cleaned up properly then it will have to come off for a nice bath and rebuild.
    Feb 2010
    yeh thought so. Still a fair job, may as well pull it off if u pull the cams right?
    having done an on-car change of valve-stems seals, it's a MFPITA job. Would not recommend doing again.
    Apr 2010
    all the 20valve motors are starting to act up now, 20 year old motor and all.
    I say just keep driving it and keep an eye on the oil level.
    Feb 2010
    fair enough. well its not hard to look after, just add oil in and keep an eye on oil pressure. I think the worst bit would be trying to get parts for them no?
    Chiba
    I've done stem seals on a 16V in car. With the correct seal pliers, it's not hard at all.
    Oct 2009
    The problem is that say a 45,000km 20v motor from Japan has been sitting around for a long time. The moment you start giving it regular oil changes the valve stem seals just fall to bits. Ideally if you were in the market for one, you would rebuild the whole motor or rebuild the head straight away. Would save a lot of hassle. There are a couple of very handy guides on how to change the valve stem seals out there.
    Apr 2007
    Are you sure its Black smoke as Black smoke is excessive fuel & Blue smoke is excessive oil ..
    Feb 2010
    well i cant see it perfectly cause it comes out the exhaust while driving under decent load, but its gotta be oil, im using 1 ltr per month and my fuel economy is sitting pretty steadily at about 450kms per 36 odd ltr fill. Possibly could be fuel, but then where the hell is the oil going? lol
    Oct 2009
    Get somebody to follow you down a hill with the engine under load (i.e at 5000rpm). Other option is to do a compression test. If a cylinder or 2 is down on comp your rings might be worn. But knowing 20v's it's pretty likely to be valve stem seals.
    Aug 2010
    Definitely sounds like you're burning oil then. Do a compression test, dry then wet, and that will narrow down what cylinder/s are having problems, and whether its the rings or the valves.
    I'd much rather be changing stem seals than piston rings.
    Apr 2009
    California
    does it smoke on startup? thats a common sign of valve seals, pooled oil drains into combustion chamber while sitting.
    1983 KP61 - High Comp 4AGE, Celica-Supra Rear, etc.
    1971 Volswagen Baja Bug - 1835cc, Megasquirt, Type 2 Trans
    1997 KZN185 - 3RZ W59, Tundra Front Coils, ELocker
    Jan 2007
    queensland
    are you using stupidly thin oil?
    Administrator Backyard Mechanic
    Jul 2009
    VRS kits are still in plentiful supply from toyota... Last time i got one it was cheaper for the entire rebuild kit than just the VRS
  1. 1JZ Has Smoke After Back-Off
    By jak in forum Tech and Conversions
    Last Post: 20-09-2007, 08:25 PM
  2. AE102 -> SIlvertop conversion?
    By birdie in forum Tech and Conversions
    Last Post: 11-09-2006, 09:34 PM
  3. Engine Smoke diagnosis required
    By skelz in forum Tech and Conversions
    Last Post: 11-07-2006, 11:26 PM
  4. blowing smoke on boost, 1ggte, clean motor!
    Last Post: 05-05-2006, 04:58 PM
