Results 1 to 4 of 4
Thread: 1jz vacuum lines.. locations etc
    Aug 2009
    Default 1jz vacuum lines.. locations etc
    hey guys... any one got a vacuum lines diagram for a z30 1jz?.. even if you have very good manifold pictures i can work it out myself...
    just got my motor at work thats pritty stripped and need to figure out where things go.. thanks guys..
    Aug 2009
    Default Re: 1jz vacuum lines.. locations etc
    found this online after a pritty good search thought id post it up.. makes it alot easier for you guys to help me out.. just quite abit unsure were and what most components in the system are.. like for example which component is the map sensor etc.. and are all of these really needed?
    Junior Member Grease Monkey BEVANI's Avatar
    Apr 2008
    top far right is your map sensor, bottom far left(17630) is the power steering vac switch switch.
    23285A is a check valve
    17650E is a vacuum switch
    23265 is a filter for the map sensor
    the hose that is circled in red i would be guessing goes to the charcoal cannister maybe???
    thats all i can think of off the top of my head
    check this page. it should help a little
    http://www.toyodiy.com/parts/p_J_199...VZ_1708.2.html
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    ░░▒▒▒▓████ JZA61 FTW!
    Aug 2009
    thanks mate!.. really appreciate it..
    Last Post: 12-07-2019, 06:11 PM
  2. 1JZ and 2JZ engine repair manuals - plus more
    By nitros13 in forum Tech and Conversions
    Last Post: 31-01-2009, 08:31 PM
  3. w58 with 1JZ
    By hecate in forum Tech and Conversions
    Last Post: 25-07-2008, 12:24 PM
  4. Vacuum relative to economy?
    By Andrew162 in forum Tech and Conversions
    Last Post: 19-01-2006, 10:03 PM
