Results 1 to 11 of 11
Thread: 4agze cas vs 20v blacktop cas
    Jun 2006
    Default 4agze cas vs 20v blacktop cas
    i am currently trying to start my blacktop 20v turbo conversion running an adaptronic 420c ecu, and i am unable to get spark on cranking. the settings i have on the ecu are from my old 16v setup running a 4agze CAS, and now i am using the 20v cas minus the dizzy. So i was wondering if there is a big difference in the two different cas? needing completely different triggering settings, or if i am chasing the wrong thing here to achieve spark?
    your help would be much appreciated
    edit i forgot to mention i am running the 1nz coil over plugs
    Can't touch this Backyard Mechanic boona's Avatar
    Aug 2008
    Default Re: 4agze cas vs 20v blacktop cas
    Look at the two cas' and see if internally they are doing the exact same thing, eg. same no. of teeth, wiring etc.
    Also make sure the wiring is schmick. Dodgy crimp terminals didn't cut the mustard on mine. Good luck.
    1987 AW11 MR2
    AE92 4AGZE, S15 T28, Adaptronic E420C build in progress
    http://www.toymods.net/forums/showthread.php?t=53945
    Professional: www.danswell.org
    Jun 2006
    cant really see the pick ups inside the 20v cas, there is a cover over all that. can anyone confirm which pins/colour wiring off of the 20v cas is for NE, G2, G1 and G-. not sure if i was given the wrong information on this maybe
    Aug 2008
    Can't remove the cover?
    As I found with my CAS, the wire colours weren't accurate. I had to actually open it and check each pickup.
    Otherwise, try every wire combination...
    1987 AW11 MR2
    Jun 2006
    sorry you can see the pick ups but there is a plastic plate in the way of the wiring to chase it.
    sorted the problem today, the NE and G1 were arse about compared to the 16v colouring.
    got it started but 800cc injectors are throwing way too much fuel in. will leave that bit up to the pros
    Aug 2008
    Too easy!
    well done
    1987 AW11 MR2
    Administrator Backyard Mechanic
    Jul 2009
    Sweet, planning on running 20v cas on my build too
    Jun 2006
    Yeah glad it wasn't anything too wrong, thanks for the help
    Cleveland QLD
    Hi Andrew
    Well done on getting a start. Have you had a chance to send the connector for my CAS. Also now that you have completed the conversion do you want to sell your old CAS.
    Todd
    Jun 2006
    Hey Todd, no sorry I havnt had a chance to send the plug, every spare moment I've been in the garage lately. It actually made it a bit easier to chase this issue still having the plug, but will try and send it this week. Will let you know when I do. Not looking at selling the cas atm, at this point I want to keep all the old 4agze together
    Cleveland QLD
    Quote Originally Posted by fandio View Post
    Hey andrew
    Thanks for the reply. When you get a chance that would be great. Let me know when you get the car sorted and I will try and see if you are going to Lakeside or QR.
    Todd
  1. 4agze build questions
    By ae86boy in forum Tech and Conversions
    Last Post: 06-11-2011, 03:59 AM
  2. 4AGZE Compression Advise needed
    By _FNQ_rolla_ in forum Tech and Conversions
    Last Post: 26-10-2008, 09:25 PM
  3. Discussion: Blacktop 20v: The road beyond 200hp
    By 86er in forum Tech and Conversions
    Last Post: 18-01-2007, 11:31 PM
