Results 16 to 19 of 19
Thread: 18rc pollution diagram
    Default Re: 18rc pollution diagram
    I see the pics on your engine has the air pump?
    My silver one doesn't have that, nor did Trini (before she was upgraded), so pics of their vacuum pipes wouldn't help you.
    However, I do remember the 28 that Hairy_Apes_22 owns has the air-pump set up, and it is full stock. You can PM him and ask for some pics. His car has a different shape air filter box to what mine have, and also has the flap to suck in warm air from the exhaust when the engine is cold. Again, mine don't have that. I was of the beleif that the pre air pump engines were earlier than the air pump ones... but I've never really investigated this.
    seeyuzz
    river
    Eltham vic
    thanks river i will do that
    did you recover ok fom new years eve
    Yeah, I had a quiet one. knocked off a few Benedictine's and then went to bed around 1am.
    Got woken up at 6am though, which was not good. So will sleep well tonight.
    seeyuzz
    river
    Eltham vic
    i pulled the carby off today and cleaned out all the shit
    i found that the heat riser pipe from the exhaust manifold had been blocked off i left that coz it would be real rare for me to have to drive it in the snow , with that being blocked it made two of the vac tubes not working
    that suits me as i couldnt find out where they went anyway
    i found that one of the vac lines that went from the carby to the distributor was arse about
    causing the vac advance to not work over 1500 rpm
    since i swapped those around not only does it pull better , now the secondrys open
    it even pulled a skid , not bad for a slushmatic
    this should now be in the WMMH section
    after hanging rock car show , the 18rgeu and 5 speed goes in
  1. 18r - 18rc front rear sump swap?
    By thdevilshands in forum Tech and Conversions
    Last Post: 15-11-2008, 07:08 PM
  2. 18r - 18rc Front Rear Sump Swap
    Last Post: 12-11-2008, 08:14 AM
  3. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 12:29 PM
