Results 16 to 19 of 19
Thread: AW11 wheel bearings and CV boots
    Junior Member Conversion King
    May 2010
    Default Re: AW11 wheel bearings and CV boots
    Apparently the AW11's are identical to AE82's, just swap the front/rear and rear/front.
    Taken from s2d4's thread on MR2Aus, the NSK part numbers are:
    Front Bearing
    NSK: 28BWD01ACA60
    Rear Bearing
    NSK: 38BWD01A1ACA147
    Diserter Domestic Engineer
    vic
    Thanks for that! I managed to get the fronts out after a bit of coercion and matched them up with AE92 bearings and seals which were $20ea cheaper than the listing for the AW11.
    May 2010
    Just to clarify, AE92 rears matched the AW11 fronts?
    vic
    Yeah the AW11 front bearings I purchased were for the AE92 rears, the NSK part number is the same you've list (28BWD01ACA60). I took the old bearings into statewide bearings, they had no listing for the MR2 but the dimension matched the AE92, the only issue was the bearing seal is listed as 40mm but they've only sold them with 41mm seals and the 41mm is the correct seal.
    The prices I was quoted from veale's was $65 for the AW11 listing and $45 for the AE92 listing and they had different part numbers. Handy knowledge especially when the AW11 prices are going up as parts are phased out.
  1. ae86 te71 disc brake rear wheel bearings
    By SRacin in forum Tech and Conversions
    Last Post: 31-01-2006, 05:43 AM
  2. More 4-to-5 stud hub conversion data
    Last Post: 19-01-2006, 12:40 AM
  3. st162 wheel bearing/stub axle
    By BeRad in forum Tech and Conversions
    Last Post: 15-10-2005, 08:29 AM
  4. Replies: 4
    Last Post: 08-09-2005, 12:17 PM
