Results 46 to 60 of 61
Thread: Aircon Issue 1JZGTE
  1. #46
    Feb 2009
    Default Re: Aircon Issue 1JZGTE
    Quote Originally Posted by JZA70R_92 View Post
    oh wtd can that cause it to cut off as there is a dash mat on and over the sunlight sensor..........Guy at the time reckon TX valve is fine and also correct pressure....hmmmmm
    Nothing i can think off but that was just an example, but will alter vent temps as ther is no heat load sensed.
    The tx will normally run fine for about 10 mins or so, depending on how much work the a/c has to do, they normally stick when inside temps are right down and the tx is almost shut. Its stick there but wont open back up so the car start to get warmer and warmer. The system needs to be shut down and wait and it normally opens back up after awhile and will work again.
    Once again doesnt explain why you comp cuts out, but that could be another fault entirely or just barking up the wrong tree altogether.
  2. #47
    Junior Member Automotive Encyclopaedia JZA70R_92's Avatar
    May 2008
    yeah thats the problem it will run then just cut off. but if I jump it to 12volts it will run fine no problems. so what you are saying if TX was to get stuck comp would still be working though?
    1992 - JZA70 STOCK - SOLD
  3. #48
    Feb 2009
    Yep, im not familur with the system, it could have a low pressure switch in it because the low side can be sucked into a vacuum dropping it out but i doubt thats the case.
    Its a real hard to fault find something like that over the net, hell its ever had sometimes to fault find even when the vehicle is right there in front of u.
  4. #49
    May 2008
    lol well it gets interesting!! drove from hose to work today about 15mins in it turned off then what I did I gunned it in 3rd up to 60 high revs about 4500rpm and the comp kicked back in and was fine untill I got to work WTF??!!%@#%@%^@^)%^@%^%^@)%^@@%^%
  5. #50
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    Hi Mate,
    I hope you had a happy new year despite the drama's with teh AC.
    My first thought was that you have a combination of 2 problems: 1 that your system is over gassed, and 2 your FMIC is blocking a lot of the air that was ment to be flowing through your condensor.
    Hence your AC kicking in at 140 kmh, due to the extra air flow. But it now seems like you have an intermitant electrical problem, it the fault is occuring under different loads e.g. different speeds, amount of accelleration, and different ambient conditions. BTW how did you go with sticking the 12V fan in? No difference im guessing? And
    My reccomendation to save you a lot of time and heartache is to bite the bullet - and take it to a respectabile AC shop and get them to diagnose the problem and give you a written quote. Then fork out the $$$, and with this approach at least you get a warranty, something I sure your lecky couldnt give you
    Just my opinion. As Matty12 said sometimes finding the problem even when it is right in front of you car be a nightmare. Let us know how you go
    Goodluck.
  6. #51
    May 2008
    ive check all electrical parts. tested amplifier checked continuity for all wires this also happend yesterday afternoon when it was damm hot revved up and it ran fine all the way home and this morning for the 1st time I started the car and didnt have to "kick start" the compressor. another thing is my ABS is also working fine now. I can only guess due to using the incorrect loom with the 1JZ amplifier as few months ago I had issues when I plugged in my amplifier I lost REVS on the dash went to 0 didnt get a chance to add a fan will try tommorow
  7. #52
    Jan 2010
    NT
    How did you check the amplifier? Un plug and use in another car? Or with a dummy load?
    Did you check the continuity of the sensors while the system was running; particularly when it was in a fault situation? So you can start to work out what is causing the fault?
  8. #53
    May 2008
    Yeah pressure sensor got tested so did the sun sensor near top of dash. It would seem my issue has gone away went for a spin just then and it kicked into life and its actually cycling on and off now! before it would run nonstop before dying funny thing is my ABS has also come good. wierd will be keeping an eye on it over the next couple days. thanks for all your help guys will keep yas posted!
  9. #54
    Jan 2010
    NT
    VERY INTERESTING!
    Hmmn sounds like your system was over gassed and has slowly been leaking refrigerant to a point where the system can run satisfactorly e.g. not cutting out on high temp/pressure. Hope thats not the case though! BTW can you see the "sight glass" on your filter/drier? There should be a spot where you can see the refrigerant moving through. Have a look at it now that the system is running good. If your AC starts to play up make sure the sight glass hasnt changed e.g. their is still liquid refrigerant in your system = no leak.
    OR You had an intermitant electrical problem (bad earth/power or dry solder joints)
    Hopefully this issue dosent rear its ugly head again.
    Best of luck!
    Ryan
  10. #55
    May 2008
    I hope it doesnt reappear to.Well there is no leaks as he put that UV dye in it and I searched with a UV light no leaks and there is liquied in sight glass also to add its actually colder!! I tested it with a thermo and currently at 2 Deg lol
  11. #56
    Jan 2010
    NT
    Thats good there is no dye showing up... did you check the evap? An easy (lazy) way to check is just to see if the water coming out is glowing...
    So your saying its getting colder? Is the ambient conditions changing where you are? e.g. is the wheather getting colder?
    Very curious...
  12. #57
    Nov 2007
    Could be that the system was not coping well at high temperatures, constantly reaching high pressure cutout, and now that the weather has cooled down you are probably experiencing it less. But your electrician friend said the pressures are ok, unless ofcourse the TXV begins playing up at a certain time making pressures go unstable intermittently.
    Try running the A/C On Fresh and Max Fan for a few days, and see if the problem comes on less.
    Faulty Pressure Switches by any chance? I've got some spares.
  13. #58
    May 2008
    problem found Dud hydrofan temp sensor not allowing fan to blow high when it got hot with aircon on. aircon has been working fine since the 4th woot!
  14. #59
    Jan 2010
    NT
    Glad to hear to mate!
    Sounded like you had a condensing problem from the start.
    Happy days
  15. #60
    Nov 2007
    And I thought the electrician said the pressures were fine ?
  1. 1jz into MX83 Cressida A340 Issue
    By brady89 in forum Tech and Conversions
    Last Post: 16-01-2010, 05:41 PM
  2. 1JZGTE issue
    By fatboy13 in forum Tech and Conversions
    Last Post: 04-10-2007, 08:28 PM
  3. Ke20 Aircon (Retrofit or otherwise!)
    Last Post: 07-03-2007, 07:43 PM
