Results 31 to 45 of 61
Thread: Aircon Issue 1JZGTE
    wa
    Default Re: Aircon Issue 1JZGTE
    Have you checked the gas pressures, it sounds to me like it may be overgassed.
    May 2008
    thats the thing leccy reckons its fine
    1992 - JZA70 STOCK - SOLD
    Nov 2007
    Might just have to leave the compressor running constantly.
    wa
    Take it to the sparky on a hot day
    sometimes when you gas a system by the pressure and not the weight when it gets hot the gas pressures can change enough to trip the cutout switch
    is your condensor fan working also?
    May 2008
    interesting. this also happend at night cool night but could be on to something maybe too much gas...
    Nov 2007
    Check the compressor clutch magnet coil resistance with a multimeter, what is it?
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    Hi Everyone,
    Been keeping an eye on this thread for a while now.
    Firstly I will state that I have never worked on your type of car, however I have read through the diagrams and it seems as you have got everything working well.
    Just wanted to ask some questions to give you a better answer.
    1. If you get the AC running (however which way works at that time) do you run the fan flat out e.g. high speed?
    2. When the AC cuts out is thier "ice" on the suction port (big pipe) of the compressor?
    3. When the evap was cleaned was the thermistor placed back in the correct position?
    4. How is the condition of your Condensor? Do you have a big FMIC?
    5. Are you using a cowling/fan shroud?
    6. Did your lecky put a vac pump on the system before he regassed it?
    7. Is the AC system earthed correctly? E.g. as good or better than standard?
    There are a few possabilities that could cause this problem.
    Have a great new year and I will catch you 11!
    Kind Regards,
    Ryan
  8. #38
    May 2008
    Quote Originally Posted by Rhyno View Post
    Hi Everyone,
    YES also tried 1st speed.
    NEED TO CHECK
    Yes made sure by checking with orignal JZ one which was leaking
    YES 600x3?? 100mm thick
    Factory shroud on JZ hydro fan
    um think so it also oiled it up
    How you mean? so far factory style i guess
    Kind Regards,
    Ryan
    Happy new year lol.
    Same thing happend yesterday coming from work freaking hot day. aircon on about 10kms it turns off pulled over and touched the black pipe on passenger side this was freaking hot! jumped it again and pluged back into relay it worked for about 1km then off again.....
  9. #39
    Feb 2009
    black pipe as in the one from the firewall to compressor??
    If so it should be cold. Does the cools fade way just before it shuts off??
  10. #40
    May 2008
    yes cools fade away. yeah its the thin black pipe witht he pressure sensor that pipe is very hot to the touch! found out today on private rd of course doing about 140 the aircon kicks back into life not cool but cool enough lol WTF!
  11. #41
    Nov 2007
    The black pipe with the pressure switch on it should be hot, the Silver pipe the larger one should be cold.
  12. #42
    May 2008
    cool but why woudl it work at high speed? as soon as a sped up to 140 the aircon kicked in I could actually here feel the comp engaging.....
  13. #43
    Feb 2009
    It really sounds like you should get some to look at it again, it could have one or many faults causing your issues.
    I was thinking maybe your TX was sticking as ive seen a few do that especially toyota's but doesnt explain it cutting out, but may explainn the deminished cooling before it cuts out.
    It could be a air flow issue as you have a front mount( may also explain why it works at 140) and system pressures may be gettint to high and droping out.
    Could also be a fault with the climate control itself ie the box of sparks or its sensors or even something a stupid as a dash mat over the sunlight sensor for example.
  14. #44
    May 2008
    oh wtd can that cause it to cut off as there is a dash mat on and over the sunlight sensor..........Guy at the time reckon TX valve is fine and also correct pressure....hmmmmm
  15. #45
    May 2008
    I might add a 12inch fan ive got lying around as A test ill just put it on and run it stright to 12volts and go for a spin./..
  1. 1jz into MX83 Cressida A340 Issue
    By brady89 in forum Tech and Conversions
    Last Post: 16-01-2010, 05:41 PM
  2. 1JZGTE issue
    By fatboy13 in forum Tech and Conversions
    Last Post: 04-10-2007, 08:28 PM
  3. Ke20 Aircon (Retrofit or otherwise!)
    Last Post: 07-03-2007, 07:43 PM
