if you want to retain the blacktop hydraulic timing belt tensioner then you need to use the blacktop oil pump. If you dont swap that over then you have to use the silvertop timing belt tensioner, which is more reliable in my experience
If you're using the blacktop head then you can retain all your current loom etc, it's best to use pistons designed for the blacktop combustion chamber.
