Results 1 to 3 of 3
Thread: 1994 camry engine cutting out under light loads??
    Apr 2010
    Default 1994 camry engine cutting out under light loads??
    Hi i came across an unusual problem with a mates car today its a 1994 camry 4cly auto.
    Problem: Car runs fine when cold. After driving for 5 - 10 min it still idles fine but completely cuts out under light loads (approx more than 20% throttle) but will come back to life at full throttle.
    I have checked all the wiring connectors and vacuum lines to map sensor etc but no change
    Thinking of attempting to retrieve the fault codes tomorrow night cos im thinking maybe a bad TPS or MAP sensor but if anyone has any ideas im open to suggestions
    Thanks.
    Default Re: 1994 camry engine cutting out under light loads??
    could be as simple as a blocked fuel filter, maybe faulty spark plug, not sure if they have a dizzy or coils but could check those out.
    Apr 2010
    Cheers for the suggestions i borrowed a scan tool today plugged it in, went for a drive and what do ya know the car didnt miss a beat always the way so i just reset the computer and ill wait to see if the problem shows up again..
  1. MA70 --> JZA70 Conversion
  2. 1ggte, wont idle on cold start. check engine light on
    By VasH in forum Tech and Conversions
    Last Post: 11-06-2007, 07:03 PM
