Another thing could be the ring gaps. If they aren't right, then you can get blowby... especially if the ring gaps line up.
What do the spark plugs look like?? Are they all the same, or is one/two worse than the rest??
The dynamic compression read by a compression guage will be very dependant upon the camshaft. A cam designed for low end torque (ie 22R) will give a much higher reading than a cam designed for high RPM (ie 18R-G), even if the latter engine has a much higher static compression ratio. So that 185psi could actually be a low reading for your engine.
