Results 1 to 10 of 10
Thread: Strange Elec problem MR2
    Original Trendsetter Chief Engine Builder Harreh's Avatar
    Jul 2008
    Default Strange Elec problem MR2
    I'm chasing what appears to be an earth leak. When I turn my headlights on they go incredibly dim and the indicator lights come on on the dash on the inside of the car but not outside. When I turn the indicators on they work but the front left Parker fires instead of the indicator.
    AW11 Turbo build
    1UZ Soarer Turbo build
    Imitation is the most sincere form of flattery
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    Default Re: Strange Elec problem MR2
    is it starting easy >?
    Jul 2008
    just some things we need to know for a diagnosis
    1. daily driver?
    2. battery and terminal condition?
    3. alt charge rate?
    4. aftermarket allarm/imobiliser fitted?
    5. does it start/run ok
    Jul 2008
    Daily driver
    Battery is fine and terminals are clean
    Alt charges perfectly fine
    I have removed alarm for diagnosis.
    Starts and runs fine
    AW11 Turbo build
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    Need to check all earth points with a multimeter and make sure there is no voltage drop anywhere
    Junior Member Grease Monkey progkamol's Avatar
    I had similar problem on customer's car before where it been hit in the front fender. What happen was wires inside the fender got damage and shorting out somewhere. Also had the turn signal on the dash but nothing out side. In the end I traced the wire and repair & insulate them and all fixed. Hope that would help some how and good luck with it.
    Signed
    M4C
    Chiba
    Check all your ground points. Download a wiring diagram for your car and use the wiring layout to find them all.
    Jul 2008
    I found and fixed the problem, burnt out ground cable connecting to the junction box. However more gremlins are occring since repairing this
    AW11 Turbo build
    Chiba
    Now to find out why the wire burnt out.....
    Junior Member Automotive Encyclopaedia eeeyan's Avatar
    Sep 2009
    Ask the EXA crowd they know all about your car it seems.
    Wish I had a F#%ken awesome toyota.. saving for the goodness now.... stay tuned....
  1. 3VZ-FE V6 into SW20 MR2 (56k be warned!)
    By Jaemus in forum Engine & Driveline Conversions
    Last Post: 09-09-2009, 11:50 AM
  2. How-to: Converting an MR2 gearbox to FWD (SW20 to ST162)
    Last Post: 27-12-2006, 06:22 PM
  3. Strange login problem?
    By Big T in forum Toymods Car Club Membership and Feedback
    Last Post: 08-12-2005, 11:08 AM
