Results 1 to 11 of 11
Thread: 3TG water heater line
    Default 3TG water heater line
    I have a 3tg engine in my race car and i just run some hose from the front of the head where the thermostat housing is to the rear which is the heater return line port. As i don't run a heater anymore.
    I was wondering if i can just block of these ports and get ride of the hose? or does water need to run through the head for cooling or something???
    Feb 2009
    FNQ
    Default Re: 3TG water heater line
    I was wondering this too, the TA22 manual I have doesn't have any coolant flow diagrams for the 2TG.
    Cheers, Jess
    Jul 2008
    Quote Originally Posted by stouty View Post
    yes. but not via the heater hoses, otherwise the heater tap in closed position would be an issue one would assume.
    Aug 2010
    The key question here is, does any water flow through this section if the heater tap is turned off? I'm going through this exact thing with my 4AGE cooling system atm.
    Ie, the inlet and outlet points for the heater hoses can be blocked off without a problem, as this would be the case if the heater was off. However you still need coolant flow through the full system, even when the thermostat is closed (unless you're running without a 'stat) I'm not familiar with that engine in particular, but you should be able to work out the flow paths and that will answer your question.
    I think im just going to try it its ony a matter of getting to plugs and blocking the ports off see how the car goes temp wise if it gets too hot ill just put it back.
    Junior Member Domestic Engineer 71TA22's Avatar
    Carterton
    Quote Originally Posted by banana_socks View Post
    The heater tap is either on or off. Off it bypasses the heater core at the tap. On it allows flow through the core. Which is why you only get cold or hot from the heater.
    Mike
    71 TA22
    My Car
    so probaly not a good idea to block it off then???
    Carterton
    Dont block it off. You can re-route from the back of the head to the water pump and miss out the heater.
    Mike
    71 TA22
    My Car
    Tallahassee, FL USofA
    Quote Originally Posted by 71TA22 View Post
    So all the hot coolant that would normally go to the heater will go to the WP to be put back into the engine, instead of going to the radiator to get cooled down?
    Does the engine have a bypass? When the thermostat is closed, does the coolant have a place to circulate between the WP > block > head >WP...?
    Carterton
    I did not explain it that well.
    Hot coolant from rear of head into heater then the water outlet then through thermostat into top of radiator.
    Cooled water from bottom of radiator drawn into water pump then into engine.
    There is a pipe linking the water outlet to the water pump. While the thermostat is closed during warm up this diverts hot water from the water outlet back into the pump then engine to speed warm up.
    Mike
    71 TA22
    My Car
    I already have a line running from the thermostat to the back off the head as i dont run a heater its a race car. i wanted to see if i could get rid of it as it looks ugly and i wanted to neaten up my engine bay.
  1. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 09:15 PM
  2. Replies: 1
    Last Post: 15-02-2009, 08:33 AM
  3. 4age heater core water flow
    Last Post: 16-07-2007, 05:19 PM
  4. Cooling Systems - Overheating Problems.
  5. no heater tap hoses, im confused. AE86 - pics inside-
    By slide86 in forum Tech and Conversions
    Last Post: 18-06-2006, 01:15 AM
