Page 1 of 4 123 ... LastLast
Results 1 to 15 of 47
Thread: Tools to remove drive shaft nuts.
    Mar 2010
    Default Tools to remove drive shaft nuts.
    I'm trying to remove a pair of very stubborn drive shaft nuts atm, i have managed to snap a sidchrome half inch fixed rachet with a pole over the end of it.
    I'm wondering if anyone can lend/rent me a decent breaker bar or rattle gun?
    Default Re: Tools to remove drive shaft nuts.
    Where do you live?
    Breaker bars can be had pretty cheap, $30 - $40 for a 1/2 inch drive with lifetime warranty... well worth the investment if you are going to be working on cars in the future.
    I am the sun
    Troublesome MR2 1st year Apprentice
    May 2007
    funny you mention this, i broke my breaker bar a few days ago trying to do the same thing, i bit the bullet and went out and bought a rattle gun and it got it with ease...
    if you were in SA id let you borrow it...
    Junior Member Grease Monkey tojo's Avatar
    Aug 2009
    Norway
    Get a cheap socket , weld it on to a 30cm flat or angle bar and hit it with a hammer.
    KE17 TE38 KE35 KP61 KZN130
    Mar 2010
    Well i got a breaker bar and got one side off!
    And snapped the bar on the other side.....
    Off to see if i can get my money back.
    Aug 2009
    Norway
    Wouldn`t mention if you used a pole or pipe on it...
    Jun 2009
    Yeah they can be pretty awful to get off, especially since the nut is so small, I always had problems of it just slipping. Big rattle guns seem to work, breaker bar with another bar attached to it, locktight has a spray that freezes the bolt (I bought some recently and it didn't seem to do much although I've heard its pretty good)
    Quote Originally Posted by Euphoria View Post
    Rost-off. You want Wurth Rost-off, or Rost-off Ice.
    As aforementioned. Large breaker bar. Pole over breaker bar. Boom.
    Can't touch this Backyard Mechanic boona's Avatar
    Aug 2008
    I use a 1/2" breaker bar with a 1m length of steel pipe on the end of that. Put it on, and stand/bounce on the steel pipe. Haven't broken anything yet, and done it multiple times. Even used a super cheap auto socket, and it was fine. Maybe keeping the angles perfectly square helps to prevent breakages? I use mostly sidchrome gear.
    1987 AW11 MR2
    AE92 4AGZE, S15 T28, Adaptronic E420C build in progress
    http://www.toymods.net/forums/showthread.php?t=53945
    Professional: www.danswell.org
    Tasmania
    Just FYI if you were using the loctite on the nut in this instance it will actually make it worse, when metal cools it contracts, making the nut tighter on the axle, in this case you want to put it on the axle.
    1973 TA22
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    make sure u use a 7 point socket too, not a 12 point or whatever they are
    Oct 2009
    A 7 point socket ay?
    I have no idea how you guys break stuff like you do
    Chiba
    An impact socket will never break, and if you use a 3/4" socket, I doubt you will break your bar either
    Oct 2009
    Quote Originally Posted by TERRA Operative View Post
    They do break, they just dont shatter. More often than not they deform, flog out or sheer in two
    Unless your spending $600+ for a 3/4" socket set those cheapo sockets are dangerous, dont be surprised if you break your bar with them.
    Tasmania
    ive used a jbs (tools work bought for me, im a kingchrome man at heart) 1/2 drive breaker bar, its done harmonic balancers (using starter motor undo method) and many drivehaft nuts (with long extensions).
    point being decent tools last.
    1973 TA22
    Last Post: 12-07-2019, 05:11 PM
  2. 4AGE 100kW Dizzy Oil Leak Guide
    By Talasas in forum Tech and Conversions
    Last Post: 05-11-2014, 08:00 PM
  3. Replies: 2
    Last Post: 10-03-2009, 04:29 PM
  4. Verifying a w58 gearbox
