Results 31 to 45 of 47
Thread: Tools to remove drive shaft nuts.
    Oct 2009
    Default Re: Tools to remove drive shaft nuts.
    ****s have been doing that for years with normal bars
    I do it on a few excavator final drives, stupid engineer made a drain plug with a 5mm hex socket and after being tracked through mud, rocks, dirt, sand etc they seize up. Stick a shitty bar with a bit of pipe over a inhex socket, lean on it and give it a good hit with a big hammer and hey presto
    May 2010
    I agree you can do it with a normal bar but these get into tight spaces and seem to direct the impact better. Just thought I would put it out there in case no one has seem them....
    Oct 2009
    Sidchome also make one, but they also make the biggest and best 1/2" breaker bar.
    750mm of awesomeness, its a special order and the sore point of the snap-on rep
    Chiba
    Anyone got any ideas on how to hold a hub from rotating in a car that has the gearbox removed, and the brakes inoperative(installing ABS)???
    The passenger side nut is just a little tight on the Levin and I need to swap the shafts to the LSD type for the 4AGZE swap.
    May 2010
    Put a tyre on and put the wheel onto the ground would be the only way besides a rattle gun that I can think of. Try a steel wheel if the centre hole in the alloy is to small
    Nov 2007
    You should specify where in NSW you are if you looking to borrow some tools. its a big place
    Oct 2009
    Stick a bar through the studs and jam it in the ground
  8. #38
    Chiba
    Quote Originally Posted by td42gq View Post
    only problem is that the car has no wheels at all and is on stands, the rims are awaiting tyres.....
    Quote Originally Posted by dnegative View Post
    Tried that, and bent my bars (including a spare rear lateral arm). I'm thinking of welding up a bar onto a circle plate that has the stud pattern drilled into it, which I can bolt to the hub then brace to the ground.
  9. #39
    Oct 2009
    Quote Originally Posted by TERRA Operative View Post
    Fuck, it seems every man and his dog here buys dodgy cheap arse tools
    Circle plate is a good idea, weld a big bit of RHS or something off it.
  10. #40
    Aug 2010
    Going through this myself atm. First side came off easily (too easily actually, quite loose) but the other side is a bit trickier.
    Getting enough torque isn't a problem, my breaker bar is decent and i've got a real nice 2m extension for it. But finding something to brace it with is proving harder. Shoved a bit of angle iron between the studs and twisted that like butter. Some pipe didn't fare much better. Then somehow I managed to bend my friggin crowbar.
    The issue is finding something with a thick enough wall so the section won't collapse locally, and long enough that the whole hub doesn't just rotate around the end. Being a cheapskate makes it harder
  11. #41
    Oct 2009
    Go to a tool store and buy a chrome vanadium jimmy bar
    http://krewtools.com.au/index.php?pa...mart&Itemid=33
    That's what you want, you will break the hub before you bend or snap an OTC bar
  12. #42
    Chiba
    Nah, the 1/2" Sidchrome socket is still going strong, it's all the scrap metal bars that are bending.....
  13. #43
    Oct 2009
    People put all sorts of shit on the Taiwan made sidchrome stuff, never seen any of the ratchets, normal sockets or bars break. Guys at work use and flog them like no tomorrow, I've got a bunch of SWG sockets (made by stanley/sidchrome) and they are bulletproof. Same goes for all the repco gear, cant break it and all of the older (snap-on staple customers) guys like it. Seen a few of their sockets with the chrome worn off (not flaked) from so much use without fail
  14. #44
    Chiba
    I use my Sidchrome retchets like hammers and generally abuse them (pretty badly actually) and they just wont break.
    Their 1/4" ratchets suck hard though. I hate them, the direction selector lever is loose on both of mine and wont stay in position.
  15. #45
    Oct 2009
    Yeah they can be iffy but it seems all 1/4" ratchets bind up and fail with enough use.
    Last Post: 12-07-2019, 05:11 PM
  2. 4AGE 100kW Dizzy Oil Leak Guide
    By Talasas in forum Tech and Conversions
    Last Post: 05-11-2014, 08:00 PM
  3. Replies: 2
    Last Post: 10-03-2009, 04:29 PM
  4. Verifying a w58 gearbox
