Results 1 to 3 of 3
Thread: Wheel offsets for RA23
    Mar 2010
    Default Wheel offsets for RA23
    Hello.
    I have a friends RA23 that i am helping him with.
    It has a boosted and intercooled 1GGZE and a few other mods.
    The deal is he wants to go for the semi Japanese look of big wheels. guard mirrors and flares.
    I think it will look kind of tough.
    The issue I have is wheel off sets to fill the flares. I was thinking 17 x 7.5 +12 front and 17 X 8.5 +4 rear or should I stick to that size and + 20's all round?
    Does anyone have any idea what offsets to run to get the right look and stance?
    Nov 2009
    Default Re: Wheel offsets for RA23
    if you want to fill out the flared you'll have to get wheels with a negitive offset, check SSR rims, Impul, BBS, Simmons rims.
    It depends how big the flares are. Standard rims are around the +20 offset. The way I would do it is this:
    1. take a stockish wheel with known width and offset (can be measured reasonably easily) and place it on the appropriate end (front/rear).
    2. measure the distance available on the inside, and distance available on the outside
    3. new offset to fill guards would be (current offset less (distance avail on outside less safety gap (say 10mm))). This is assuming you have measured with the same width tyre. If not, then you need to increase the offset by half the width difference between the old tyre and new (assuming new tyre is wider).
    So for example:
    Take a +20 wheel with 195 wide tyre and you measure a gap of 40mm, and you want a safety margin of 10mm. The new tyres desired are 215 wide. So the new offset would be:
    20 - (40 - 10 - ((215-195)/2)) = 0 offset. Of course, under the same scenario if the measured gap was 60mm, you would now need -20 rims.
    Hope this is clear enough??
  1. wheel offsets 4 ma61
    By [email protected] in forum Tech and Conversions
    Last Post: 29-08-2009, 12:02 PM
  2. changing wheel offsets
    Last Post: 25-05-2007, 06:39 PM
  3. XD, XE, XF Falcon wheel offsets
    By Gabe in forum Tech and Conversions
    Last Post: 26-01-2007, 10:46 AM
  4. Wheel offsets and spacers.
    By Big T in forum Tech and Conversions
    Last Post: 07-05-2006, 08:44 PM
  5. lexus wheel offsets?
    By SL666 in forum Tech and Conversions
    Last Post: 11-01-2006, 06:33 AM
