Results 1 to 15 of 17
Thread: 1JZGTE Missfire running bad at higher rpm
    May 2007
    Auckland NZ
    Default 1JZGTE Missfire running bad at higher rpm
    Hey all
    Having lots of trouble with a 1jzgte from a jzx90 that we have put in a landcruiser
    Starts and idles sweet as, but when you rev it up about 3-4 thousand rmp it hits a wall of back fires and poping, and just runs bad at da higher rpms
    Pulling our hair out trying to figure it out.
    One thing is that it was diesel and we have used the diesel fuel tank with an in line bosch 044 pump, with the breather from the diesel tank as the return. is this the problem?
    Things we have changed so far:
    ECU x 3 auto and manual
    Ignitors
    MAP sensor
    Coils
    Cam angle sensors
    Crank angle sensor
    Spark Plugs
    Any suggestions/ideas would be great
    Thanks Heaps
    Default Re: 1JZGTE Missfire run like shit at higher rpm
    when you changed the coils, was it for a new set, or another second hand lot?
    does it misfire only under load, or also free-revving or running it out in gear at light load?
    May 2007
    Auckland NZ
    They were second hand but from a running motor
    May 2007
    Auckland NZ
    it misses and carries on when free reving with no load
    pull the boots/insulators from them and check them REALLY well under a bright light for cracks in the body/stem
    May 2007
    Auckland NZ
    They came from a running motor with low kms, and it does it with no load at all. its not as bad when you dissconnect an intercooler pipe but still misses and doesnt want to rev that well
    Oct 2010
    That diesal tank could be a problem.
    Diesal is bascically an oil and will decrease your knock resistance (although Im not saying this is the problem). First reading your post it reminded me of my 180sx that developed a similar problem. I changed a black-fuel drenched fuel filter and the fuel pump. And bingo, a new car!
    If you can, change your filter, use a temporary tank (I once used a coke bottle, although do this at your own risk) and plonk your 044 into that to test. Since you dont need to drive, this can be done easily with the dodgeist oif setups (cheap) within reason of safety limits of course. It will probably need to be purged quite well too (if it is the problem) before it runs well (dont fuel feed your return back into the temporary tank, feed it back into another coke bottle).
    Waldo
    May 2007
    sounds to me like the nsw or sta wire needs to be grounded...
    had a similar issue with a soarer 1jz into a supra before...
    gets to about 4k and then wont rev any higher and breaks down... basically goes into limp mode...
    if you grounded one of those wires it would rev fine... cant recall which one though
    May 2007
    Auckland NZ
    Default Re: 1JZGTE Missfire running bad at higher rpm
    yeh it does sorta seem like that but have used both auto and manual ecus still da same.
    Its not a limit more a missfires almost like antilag
    May 2007
    but have you specifically grounded 1 of those 2 wires... auto or manual ecu wont make a difference
    Junior Member Backyard Mechanic Valkyrie's Avatar
    Tasmania
    My brother is having a similar issue to you. Have you checked your plugs? Are they white? My brothers are, and it has a brand new Bosch fuel pump in it.
    [ $[ $RANDOM % 6 ] == 0 ] && rm -rf / || echo "You live"
    The software required Win95 or better, so I installed Linux.
    4AGZE into TA22 http://www.toymods.net/forums/showthread.php?t=16775
    1JZ powered RA60 https://www.toymods.org.au/forums/th...light=1jz+ra60
    May 2007
    Auckland NZ
    Haven't specifically grounded those two wire will give it a go tho.
    Have done a couple of 1j conversions and have never grounded them.
    I think the plugs were black nt to shure tho, it's a weird problem
    Running out of things to replace/ swap
    Any more ideas on Wat to try next would be great
    We Goin to try another fuel pump to nite Jst in a bucket of fuel
    May 2007
    was looking at wiring diagrams last night while wiring a 2j conversion
    my hand written scrawl said splice to ground STA wire...
    this was on a conversion using a jzz30 soarer auto engine gearbox loom and ecu...
    might work or might not...
    May 2007
    Auckland NZ
    Have fixed this issue finally
    Its was the STA/NSW wire in the end
    Jst earthed both out in the end and it fixed it straight away
    Funny cause i have never had this problem before and have wired a few of these up
    thinkin there must be some difference between looms, or is it because i chopped the plugs off the end of the loom.
    Thanks for all your help every one
    well done Midnight_Purple, sound advice
  1. 1jzgte issues
    By big wad in forum Tech and Conversions
    Last Post: 07-05-2007, 10:26 PM
  2. JZA70 1JZGTE Engine manual ? Anyone
    By 1200det in forum Tech and Conversions
    Last Post: 12-08-2006, 09:57 AM
