Results 16 to 21 of 21
Thread: 1JZ-VVTi output limit - 260-280kw it seems =|
    Default Re: 1JZ-VVTi output limit - 260-280kw it seems =|
    Anyone have any head flow figures between the original 1j, vvti 1j, 2j and vvti 2j? Would be interesting to see there really is somewhat of a big difference.
    Mr Shabadoo.
    Daily JZX100
    Nov 2010
    tasmania
    there is a big difference.
    on pf, tk has a thread on the 1j and 2j heads with porting and flowbench data. not too sure about splashing his data around, but cant be searched under tk 1j engines etc.
    i think you will find the main reason is that most peoples budget only allows for those sort of mods as it will cost you alot more to make 400kw than what it will to make 300kw's
    May 2006
    Die grinder + commodore AFM conncted to a multimeter and an inline 240V AC extension blower = ghetto flow bench love
    BMW Sapphire black JZA80 1st year Apprentice iwantablackrz's Avatar
    Jul 2007
    I was under the assumption the main restriction was that the exhaust ports are too small. Obviously this improves the low down torque and probably improves the rate in which the CT15B starts to make boost but obviously in a higher powered application that's going to be an issue.
    I'll agree with the general consensus though. 'Most' Vvti 1JZ seem to hit a wall at 280rwkw'ish. There's a few getting around that push through the barrier though.
    Project Polar Bear is here! '97 JZA80 Toyota Supra RZ-S| '93 JZA80 Toyota Supra SZ with VVti 1JZ R.I.P | '93 ST195 Toyota Caldina Current l
    Junior Member Grease Monkey 50RTD's Avatar
    May 2009
    Quote Originally Posted by beerhead View Post
    Hahaha classic!
  1. 1JZ VVTi help please anyone?!
    By Dylo in forum Tech and Conversions
    Last Post: 19-10-2010, 03:04 PM
  2. Raising rev limit on 1JZ vvti???????
    By swapinthedark in forum Tech and Conversions
    Last Post: 30-08-2008, 10:32 AM
