Emissions was based on ADR27a (same as it was when the car was complied in 1977). Test is an IM240 emissions test, done at either Lane Cove or Penrith RTA testing facility (no charge). Basically they run your car through a speed up, slow down cycle on a dyno with your exhaust going through a sensor which measures unburnt hydrocarbons, CO, CO2 and NOx levels (total quantity, not percentage). If your cumulative quantity over the test cycle is below the limits specified in the relevant ADR, then you get a pass.
For the engineering specific to EFI and turbo mods, the Engineer wanted a pass on the emissions test, charcoal canister connected and plumbed to intake, catch can plumbed to intake, cat converter installed, noise test pass (to ADR of 1977), air filter boxed. That was it. He didn't care that the ECU tune wasn't locked. Also had to pass a general road test. Plenty more testing and compliance for all the rest of the mods (6 page report). Even did a platronics brake test (70/30 front/rear brake split - awesome!)
A mate of mine in Germany reproduces cast iron and cast alloy parts for BMW's, even whole cylinder heads.
