Page 49 of 74 FirstFirst ... 39474849505159 ... LastLast
Results 721 to 735 of 1105
Thread: The 18R-GTE reference manual ...
  1. #721
    Default Re: The 18R-GTE reference manual ...
    Hey karl were your crower rods off the shelf or were they specially made for your application?
    Just curious.
    Luke
  2. #722
    Karl's rods are custom made.
  3. #723
    my rods are custom forged from awesome.
  4. #724
    ^ that is amazing! There is so much awesome that it borders on unbelievable.
  5. #725
    Junior Member Grease Monkey MnToyGuy's Avatar
    Minnesota
    Look at who stopped by today!!
    He said it is going to be a while since the guy working on it is doing it in his off time to keep it "cheap".
  6. #726
    this thread has now delivered pure AWESOME.
    did i mention i love you?
  7. #727
    I foresee lots of man love in this thread.
  8. #728
    Minnesota
    He didn't originally have the housing, so he stopped by to pick that up. He will check tolerances and function, then install the shaft and we'll test it with a drill and bucket of oil over a weekend to see if anything binds up or excessive wear.
    We didn't check hardness of the original parts and this is made of some standard, semi soft steel. Given it's in an AL housing and the scores on the original parts, his theory is that you want softness in case a metal shaving or something gets in there. It would move through rather than lock up the rotor, doing all sorts of nasty gear stripping and kill the motor.
    Any thoughts??
  9. #729
    From using a file to remove filings on an original toyota pump, I am pretty sure that the standard pumps are hardened to some degree. A file doesn't do much damage to them.
    I'd be looking for a similar material to the standard pump and the same clearances/tolerances too.
    I think if it's worth doing, it's worth getting it right so that they are reliable.
    That said, it is great that someone is going to the effort of actually making this happen.
    (\__/)
    (")_(")
  10. #730
    dont forget - the tolerances are in the "green book"
  11. #731
    Minnesota
    Good info on the hardness, and exactly why I posted here. We'll run a Rockwell hardness test and match it up.
    Witzl, the first thing I did was give him a copy of the page from the green book
  12. #732
    You may find that being a wearing surface it is carburized or case hardened rather than heat treated.
    Good work by the way.
  13. #733
    Gold 28. Yes, that is quite possible, I hadn't thought of that.
    (\__/)
    (")_(")
  14. #734
    Nov 2009
    tasmania
    hi all
    just bought a suck though carby turbo set up with T04 for $180 to fit single cam 18r in my hilux while i build up an 18rg
    just wanted to know everyones thoughts on the size... think it might be just a little on the big side
    will be going on completely standard motor that im not overly concerned about, will be intrested to see how long it will last!!!!
  15. #735
    TO4 comes in lots of sizes but yes it probably is a bit big for a 2L engine, especially one that doesn't like to rev much. I'd be hunting around for a cheap WRX or S13 turbo instead.
  1. GUIDE - 85amp EA Falcon Alternator onto 18R or T series engines
    Last Post: 03-05-2019, 04:25 PM
  2. 18r need to align cams/timing marks
    By Quinn in forum Tech and Conversions
    Last Post: 03-05-2006, 10:00 AM
