Page 42 of 74 FirstFirst ... 32404142434452 ... LastLast
Results 616 to 630 of 1105
Thread: The 18R-GTE reference manual ...
  1. #616
    Aug 2009
    Auckland
    Default Re: The 18R-GTE reference manual ...
    Ok so i've never seen a clutch slave cylinder before im gonna guess its this, unsure where my LED torch went so had to use a normal torch and it looks weird. this is a "roads eye view" of it, or 1/birds eye which ever you understand better.
    and also its a cellphone pic :\ dunno where he camera went, not going so good for me.
    I removed the rear springs quite easily, went to do the front, not so easy, first time doing it so wasnt sure what to do, but i took a guess and went the long way, which didnt work lol. So it turns out i have to compress the springs inside to remove :\
    Looks pretty good at the mo anyway.
  2. #617
    The first pic is indeed a clutch slave cylinder, and it is the later non-adjustable type. So you are in the clear as far as that is concerned. Next thing you will want to check is where the gearbox mounts to the body. If you can take a photo of that bracket and post it up, then we should be able to work out whether you are going to have a smooth sailing conversion or not.
  3. #618
    Aug 2009
    Auckland
    Quote Originally Posted by o_man_ra23 View Post
    Mintage. ill try take those pics tomorrow, hopefully the conversion will be like beating a type r with a 18rg... easy as
  4. #619
    Gentle giant Backyard Mechanic h3ff44's Avatar
    hey not to sure if you guys have seen this kit before but i figured someone might be interested in it...
    twin turbo kit for an 18rg... anyone got like 4.5k
    http://page5.auctions.yahoo.co.jp/jp/auction/e90610250
    if this is not related to thread feel free to delete.
    "Keep smiling, it makes people wonder what you're up to."
  5. #620
    that is just plain ridiculous.
    I'll stick to my big single thanks.
  6. #621
    Damn Nigga!! That's some whack shit!! I have enough trouble trying to fit a damned CT26 in my engine bay, let alone twins!!
  7. #622
    And some more on the twin setup.
    http://www.7tune.com/yahoo-auction-f...kit/#more-2438
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  8. #623
    Quote Originally Posted by h3ff44 View Post
    Overkill, but in a cool way
    Quote Originally Posted by ra_28 View Post
    Alex
    thats where i originally saw it and did a bit of a serach around and found one on the auctions in japland.
  10. #625
    Aug 2009
    Auckland
    Quote Originally Posted by The Witzl View Post
    Gumwah.... its actually a lot easier than reading Oman's thread.
    • Buy W55/W57/W58.
    • Attempt to get RT142 shifter position (the forward-most type)
    • Buy 21R/22R bellhousing and fork from RA60/RT142
    • Use the gearbox crossmember from your W50.
    Actually... if you buy the whole W55 gearbox from an RT142 corona, its actually a bolt in affair (almost). Just be careful its not one of the RT142 coronas with a borg warner gearbox.
    METHOD:
    1. Remove W50 box
    2. Take gearbox crossmember from W50 and put on W55
    3. Bolt in W55 box
    4. You will find that the two front-most bolt holes on the gearbox crossmember now only line up with the rearmost holes in the chassis.
    5. Get two pieces of steel angle or flat bar, around 150mm long.
    6. drill them out and bolt in according to the diagram below
    With the 21r/22r bellhousing, can i get a bellhousing and fork from one that had a w55 behind it and fit to w58? im sure i can but not 100% sure
  11. #626
    hi,
    from memery w55/7/8 bellhousing, fork etc is all the same and can interchanged at will.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  12. #627
    Aug 2009
    Auckland
    Sweet, been offered a W58 from ma61 supra, bellhousing and fork from 18rg which had a w55 behind it for around $1000NZD i think its a pretty sweet deal
  13. #628
    hmmmm, i'd be shopping around a bit personally, but i don't know what these things go for in nz. My w57, with bellhousing fork etc cost me $300. Different 5th gear ratio but otherwise the same.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  14. #629
    Aug 2009
    Auckland
    w57's have the highest 5th of all w series boxes. and lower power rating than 58 so would go cheaper of corse. the guy wants 150 for the bellhousing and fork incl shipping and 850 for the box. some of them go for around $1k depending on condition, unsure of condition of this one but have queried on it.
  15. #630
    as food for thought too. If you went with the w55 that the witzl suggested, you could probably buy a whole rt142 corona for about $500. Keep the gearbox, sell the engine and wreck out the rest of the car and possibly even make some cash! I'de also look about for an ra60 or something and do the same. 180rwkw isn't going to smash a w55 in a hurry, and if you get one from an rt142 it probably hasn't had the 25odd years of bashing that a ma61 supra probably would have had.
    But yeah, i'd still be shopping around.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  1. GUIDE - 85amp EA Falcon Alternator onto 18R or T series engines
    Last Post: 03-05-2019, 05:25 PM
  2. 18r need to align cams/timing marks
    By Quinn in forum Tech and Conversions
    Last Post: 03-05-2006, 11:00 AM
