Page 40 of 74 FirstFirst ... 30383940414250 ... LastLast
Results 586 to 600 of 1105
Thread: The 18R-GTE reference manual ...
  1. #586
    Default Re: The 18R-GTE reference manual ...
    Quote Originally Posted by Sagluren View Post
    just a note, there are two different torque setting for the cam caps. one is very wrong the next page is correct. be wary and don't get your little brother to torque them up for you.
    In which section mine is correct on both pages in cylinder head section. 12.3-16.6 ft-lb.
    Maybe i'll go and check in the other 4 18r books i have. What is the number on the back cover and date when printed.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  2. #587
    Found the mistake. Book 98196 page 5-27 fig 5-87 tells you to torque the cam caps to 72.3-86.8 ft-lb but if you read the txt it's talking about head bolt, where it should be talking about tightening sequence Books 98142 is correct. Book 98196E has correct torque settings but still calls them head bolts instead of cap bolts. LOL
    Also
    Book 198196 states 8.7-13.0 ft-lb
    Book 198196E states 12 15 ft-lb
    Book 198142 states 12.3 16.6 ft-lb so take your choice
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  3. #588
    I would love to eat a... Domestic Engineer Sagluren's Avatar
    south australia
    thats the one, ill find out what book i have when i remove the shed,
    be wary.
  4. #589
    farkernell! That's solid!
    Is that a magnetic reluctor pickup?
    yeah its pretty beefy! I wouldve gone the next size down trigger disc, but it was about 15 or 20 mm diameter smaller, and i thought that might be too close to the pulley diameter and cause signal issues.
    Yes its a VR sensor.
  5. #590
    LOL got that right. Are you going into the lumber business Witzl?....18RGT powered log saw
    Hi Guys,
    I have posted a parts wanted thread for an 88211 generation 18RG inlet manifold.
    Will swap for other usable manifold that I have.
    link is here:
    http://www.toymods.net/forums/showth...11#post1037111
    (\__/)
    (")_(")
  7. #592
    It seems that way.....
    I dont really give a crap, so long as i have a nice, healthy, ACCURATE trigger for the Adaptronic. This is something the chain/gear driven dissy is not able to provide.
    Knowing now how Jase was able to attach the trigger wheel to the crank pulley, I couldve used a smaller diameter wheel.
    But hindsight is blinding like that.
  8. #593
    Quote Originally Posted by The Witzl View Post
    Just stiring mate It's in keeping with the 'solid' nature of the rest of an 18RG bottom end anyways As long as it does the job
    BTW, the teeth numbers are specifically to suit the meagsquirt?
    Nah, 36-1 trigger wheels are pretty universally used. Suit Haltech, Motec, MS and all the usual suspects.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  11. #596
    yeah the teeth numbers are more suited towards a Megasquirt... but the Adaptronic is configurable so it will work just fine.
    Reading the adaptronic manual, it seems that it has a maximum of 30-pulses per 360* engine rotation... so because i have 36(minus 1), I have to program it to "skip" every second pulse, essentially making an 18-1 trigger wheel.
    ... i need to read more tho
  12. #597
    Aug 2009
    Auckland
    Quote Originally Posted by ra_28 View Post
    I have an 18rg manual. What torques you after.
    Alex
    Well pretty much all of them, if it wouldnt be much hastle scanning the pages?
  13. #598
    Gumwah, there is a link on these forums somewhere to a full scan of the 18r green book. But I can't remember where at the moment.
  14. #599
    south australia
    classic celica index thread will have the link
  15. #600
    For starters 18rg specs
    http://www.toymods.net/forums/showth...ght=18rg+specs
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  1. GUIDE - 85amp EA Falcon Alternator onto 18R or T series engines
    Last Post: 03-05-2019, 04:25 PM
  2. 18r need to align cams/timing marks
    By Quinn in forum Tech and Conversions
    Last Post: 03-05-2006, 10:00 AM
