Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
Thread: MAKING a 1.5J what can i use from 1j on to 2j
    Default Re: MAKING a 1.5J what can i use from 1j on to 2j
    Quote Originally Posted by jak View Post
    the gte versions are meant to have a higher flow rate.
    I guess that's logical to cope with the extra demand of the piston cooling separate oil squirters in the block of the turbo motors yeah? Is that why I assume?
    TRB01J Backyard Mechanic jak's Avatar
    Jun 2007
    no were going to a full 2j.
    yeah im sure. i just 2jzge converted my mx83 and i threw on a 1jzgte oil pump so i had the cas for when i go aftermarket management.
    Jak
    '77 RA28 Celica - Repairing Rust...
    '84 AE71 Daily Driver/Race Car
    '91 MX83 - Fastest Standard Turbo 1JZ Powered Vehicle In The World -
    10.74 @124 Mph
    http://www.youtube.com/watch?v=H2ido6yirZ8
    No worries. So a GTE pump will fit a GE?
    I assume that most guys drill the block for oil feed or run a feed off a sandwich plate from the filter block
    MX83 Grande 1jz GT35R buildup here.
    http://www.toymods.net/forums/showth...ghlight=grande
    Some say that his heart has 6 cylinders. All we know, is he's called,
    Jun 2007
    yea. i opened both up a while ago and iirc the ge runs a gear style pump while the gte is a cresent.
    Jak
    10.74 @124 Mph
    Cheers. Thanks Jak.
    im running GE block, better to have oil on bearings then forged pistons.
    8.3 et PB 169 MPH PB
    Hey Shane.
    I assume that you are running a standard crank with aftermarket rods and pistons.
    Did you guys drill the block for the oil feed or use a sandwich plate on the filter housing?
  8. #38
    Jun 2007
    I dont see the big deal in putting the oil squirters in a ge.
    everyone says "not worth it", which may be true in a drag application, but wheres the skill in taking a few measurements, milling a flat and tapping a hole?
    Jak
    10.74 @124 Mph
  9. #39
    Aug 2009
    whats the go with the oil gallery port in the head.. Anyone got any pictures of this?
  10. #40
    Re: Oil squirters. An engine with forgies doesnt exactly need oil squirters anyway. Based on the fact that most use (except mahle) high silicone, high expansion aluminium and require a descent amount of heat to run at their desired clearance anyway.
    Most rely on oil slinging out from side clearance on conrods.
    OEM style pistons possibly a different story.
  11. #41
    Quote Originally Posted by mr1jz View Post
    Hey Shane.
    yes stock crank, puater rods, TMS race pistons.
    oil feed is run off the oil pressure fitting
  12. #42
    Quote Originally Posted by jeffro ra28 View Post
    exactly Jeff. i remember my first built motor i bought second hand, had so much clearance it sounded like an old diesel motor slapping around until it came up to temperature.
  13. #43
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Chill out champ, a little bit of banter/humour won't hurt your thread
    I genuinely recommend you get a hold of an older copy of the Japanese EPC, they go for as little as 12 bucks, and will be useful for many of your parts needs/comparisons in future.
    Heck, i'll even copy you the 5 CD's myself and mail them to you if it helps............
    You can download it from a torrent as well. There's a version kicking around which includes the data discs up to 2007 for japan / europe / USA / general area (including Australia).
  14. #44
    Junior Member 1st year Apprentice rabbits's Avatar
    Aug 2006
    were do i get a japanese EPC discs from
    love the info guys
  15. #45
    Jun 2007
    I personally dont see the benefit in oil squirters.
    plenty of ge's are getting around boosted without them and are pulling some decent numbers. theres not many left without boost in the states.
    at the end of the day the prices of gte's are rising, and the oil squirters just arnt worth it. pickup a ge and a gte head an bobs your uncle, all for under 1k.
    Jak
    10.74 @124 Mph
  1. 1jz pistons in 1.5j motor
    Last Post: 11-06-2008, 08:23 PM
  2. 1JZ Not making boost?
    Last Post: 22-03-2008, 05:49 PM
  3. Making custom strut brace
    Last Post: 26-03-2007, 09:02 PM
