Results 1 to 6 of 6
Thread: 21r to 22re HELP!
    Oct 2009
    Default 21r to 22re HELP!
    if anyone has done this conversion can you please link, tell me some guidelines you took.
    now i have a ra60 with a 21r, an im taking a running 22re out of a corona obviously it comes with everything because its running.
    its going to be easy to put it in just the wiring is going to go over my head, will i have to change dash loom? or will the 22re engine loom plugs be the same as the 21r dash looms?
    links please!!
    Default Re: 21r to 22re HELP!
    I am not very familiar with the 21/22 engines... but the 21r is carby and the 22re is fuel injected? If so, you will need to get a fuel pump for the injected engine.
    seeyuzz
    river
    Oct 2009
    yeah i know all this changing fuel tank an lines, just need someone to help me in the way of wiring.
    0402727834 Grease Monkey turbo ke20's Avatar
    yes ive done this conversion.
    dont need to change dash harness.
    just needs some wires added to power up the ecu.
    pretty straight forward if you have mechanical and electrical knowledge.
    PROWIRE PERFORMANCE WIRING
    Specialising in:
    -Haltech
    -Full Rewires
    -Engine conversions
    -Custom Air Con. Installations
    -Drag, circuit & show car wiring
    Justin Moore
    0402 727 834
    http://www.facebook.com/profile.php?...88667244568569
    Oct 2009
    does anyone have a pinout for the electric dizzy an coil, must be circle plug?????
    Tasmania
    21R and 22RE share the same dizzy and coil so thats an easy one.
    Cheers Brett.
  1. Hilux 22R to 22RE Conversion Help needed
    By MrBags in forum Tech and Conversions
    Last Post: 09-03-2013, 01:38 PM
  2. 22re crossmember measurements
    By newbien in forum Tech and Conversions
    Last Post: 16-09-2009, 06:33 PM
