Results 31 to 45 of 75
Thread: 1GGTE head bolt options
    Aug 2009
    Default Re: 1GGTE head bolt options
    Price?
    10 char
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
    Theres some on rhdjapan, kameari branded, around $310.
    Thickness is specfied at .8mm - 3.0mm, they are a bead type gasket and suit a bore from 76mm-79mm.
    If theres interest ill check with jesse streeter to see if he can get a direct buy from manufacturer and deal through him, hes much cheaper/cleaner to deal with.
    RA23 - Twincharged
    JZZ20 - Daily
    when ur buyin any new shit keddz give me a yell
    need to have a beer with you to pick your brains about 1geegees
    Jan 2010
    Hey Kedderz,
    I'd be keen on a good quality MHG but at $310 i couldn't justify it on my current appliaction. Let me know if Jesse can get a bulk lot a little cheaper and i'll gladly chip in for one
    [SIZE="1"]"I wan't something good to die for, to make it beautiful to live"
    RA28 Celica '77 Project
    JZA80 Supra '99
    Dont know much about horses tbh......
    $310 is the righthandjapan price, so im sure it can go down alot, ill send an email and wait and see.
    RA23 - Twincharged
    JZZ20 - Daily
    Junior Member Grease Monkey 81hilux09's Avatar
    Apr 2009
    hay just a question, when installing the head studs to the cams have to be removed?
    When I did the 7m one i didn't have to but make sure you put the washers in the head before you lower it onto the studs.
    RA23 - Twincharged
    JZZ20 - Daily
  8. #38
    Apr 2009
    so got the head studs, installed them yesterday..we had to take the cams out which wasn't a problem. but following the instructions of the arp bolt saying to hand tighten them in. but when we put the washers and bolts on once we tightened them up the thread of the stud didn't fully come through the bolt.. they torqued up fine. should i be worried about this?
  9. #39
    you got the 2JZ main studs right? not the head studs?
    RA23 - Twincharged
    JZZ20 - Daily
  10. #40
    Apr 2009
    Quote Originally Posted by Kedderz View Post
    use 2jz ARP main studs for both mains and head bolts part number ARP # 203-5405
    same as these, as you said
  11. #41
    I'll let you know when I fit mine lol
    RA23 - Twincharged
    JZZ20 - Daily
  12. #42
    Apr 2009
    great ... i'll probably tell u when the engine goes boom the first time i start it
  13. #43
    Aug 2009
    let me know when that happens also
  14. #44
    Apr 2009
    you guys are leaving me with great confidence....
  15. #45
    Oct 2008
    TAS
    so the stud doesnt stick out past the nut?
    no one would design them to be like that imo.
    1983 Toyota Celica Supra
    By The Witzl in forum FAQ
  2. 1GGTE Flex Plate Bolt
    By J0RD0 in forum Tech and Conversions
    Last Post: 19-11-2007, 02:08 PM
  3. 22RE head options?
    By Shifty in forum Tech and Conversions
    Last Post: 17-03-2006, 11:29 PM
