Results 1 to 15 of 18
Thread: 7MGTE & 1JZGTE manual bellhousing competibility
    Oct 2008
    Default 7MGTE & 1JZGTE manual bellhousing competibility
    Hi Everyone, I got questions here need you guys to help me out!
    Right now! I have a 1JZ-GTE (from a soarer JZZ30)with a Auto gearbox,
    Now I would like to do a manual conversion on it!
    and I am about to buy a R154 out of a 7M-GTE (MZ21 model soarer)
    Just wondering if I can use the auto gearbox bell housing to fix to that R154 to get it running?
    Thanks
    Hen
    Default Re: 7MGTE & 1JZGTE manual bellhousing competibility
    Quote Originally Posted by tuntown2 View Post
    Thanks
    Hen
    Nope
    You'll need a xJZ to R154 manual bellhousing.
    No auto bellhousing will work (easily anyway), and the 7M-R154 bellhousing will also not work behind the 1JZ
    Wilbo's JZA80
    Wilbo's JZZ12
    Oct 2008
    Hi Wilbo thanks for your help!
    Hmm so that means I just need to get some any xJZ series model bellhousing should be able to attach to that easily?
    Just a curiosity does all the R154 box are exactly the same right? no matter which model of the supra/soarer/chaser etc.
    Yes, you'll need to get a xJZ to R154 bellhousing.
    There are some slight differences that I know of between R154s, in particular the gearbox mounting...but the bellhousings are the same for all R154.
    Wilbo's JZA80
    Wilbo's JZZ12
    Oct 2008
    Ohhh~~~ you're awesome!
    by the way how about the clutch and fly wheel from the 7MGTE are they completable with the 1JZ-GTE engine? >__<
    by the way how about the clutch and fly wheel from the 7MGTE are they compatible with the 1JZ-GTE engine? >__<
    Flywheels are different, 7M is 6 bolt with an offset hole, xJZ is 8 evenly spaced bolts.
    Factory clutch plate, pressure plate & throw out bearing are identical between 7M (R154) and xJZ (R154).
    Wilbo's JZA80
    Wilbo's JZZ12
    Oct 2008
    Hi Wilbo,
    I Just want to make sure! so I want to the Extrem Clutch website and found out that 7MGTE/MZ21 have the same dimension clutch plate with the 1JZ
    and the fly wheel just like what you said!
    Thanks Bro, really appreciated!!
    Right now is the dilemma for me,
    Because I can get the R154 for $1k but I have to source all other parts such as "clutch, flywheel, tailshaft, most with pedals and line, master, slave etc etc."
    OR
    I can just go to Wrecker and get a conversion package with the R154 for $2.5K
    Which one you reckon is better????
    I don't know what your plans are
    I.e.
    Will the pedals and tailshaft work (if you're doing a conversion into a different car then prbly not!)
    Do you want to run a factory clutch? (Will this meet your power level goals?)
    I'd prbly go the 1k gearbox option. $1500 for a bellhousing, clutch, fly, tailshaft and cyls doesn't seem like good value to me
    Wilbo's JZA80
    Wilbo's JZZ12
    if you break down the extra prices...
    JZ bellhousing - $250
    clutch master and slave $250
    clutch hard & softlines - ?? $50-200 depending on what way you go.
    JZ flywheel - $80-400 depending on if you go used or new
    JZ clutch - $500 for a good one
    tailshaft - $300-600 depending on design (one piece v-s 2 piece etc)
    Pedalbox - $50-200 depending on type and availability.
    Oct 2008
    Thanks for all the great helpful answers from Wilbroo, really appreciated!!
    Hi JP thanks for the easy reading price list which is also very helpful, so I know how much I should be paying for!
    Just wondering if you have some of those items?
    Right now I am just looking for
    ---]JZ R154 Bellhousing
    ---Fly wheel
    Not really going anything hard so far, cos it's a stock 1J engine!
    Oct 2008
    I.e.
    After thinking about it, I am gonig for the 1K gearbox and gona source the rest myself.
    Right now just need the bellhousing and flywheel
    This will be just for the 1J stock engine and weekend drift that's all, nothing hardcore
    Oct 2008
    to Wilbro again,
    My plan is to fit a 1J into a rolla..........
    hahaha
    I dont have any of those items to sell, but have recently had to purchase them all after starting with an MA70 R154 for my 2J.
    You can get a non-genuine copy of the JZ bellhousing off ebay pretty easily now, slightly cheaper than buying a new one from toyota.
    Oct 2008
    To Wilbro and everybody that is looking at this thread,
    Forgot to ask, can I use the fork and the slave from the 7MGTE and just hook it on the Bellhousing for 1JZ to R154? cos looking at it, they are both a bit similar!
    yes you can
  1. Cressida MX73 Conversions Guide Book
    By twentyEight in forum Engine & Driveline Conversions
    Last Post: 24-02-2007, 11:07 AM
